Hello;
I want to trace the evolution of entropy in my system. Can someone give me the name of the subroutine that allow me to calculate the entropy generated in a given system.
best regards;
H.SEMAI
Entropy generation
Entropy generation
Hello;
can someone inform me about the procedure to be undertaken to evaluate the entropy of a thermodynamic system modeled with saturne_code?
best regards.
Hakim.
best regards.
Hakim.
Re: Entropy generation
This is quite an open question.
For a start, you would need to add a transported variable (a user scalar) for entropy.
After that, you need to define appropriate physical properties and source terms so that it does behave like the Entropy (there is no predefined option for this to my knowledge).
Hello;
The local volumetric rate of entropy generation, based on the second law of thermodynamics, is given for three dimensional flow as follows:
S=(k/T)^2 * [(∂T/∂x)^2+(∂T/∂y)^2+(∂T/∂z)^2 ] +
( μ/T) *
[2((∂u/∂x)^2+(∂v/∂y)^2+(∂w/∂z)^2 )+(∂u/∂y+∂v/∂x)^2+(∂u/∂z+∂w/∂x)^2 +
(∂v/∂z +∂w/∂y )^2 ]
the entropy productions by heat diffusion :
the entropy productions by viscous friction:
(μ/T) *
(∂v/∂z +∂w/∂y )^2 ]
T: Temperature [k]
k: Thermal conductivity, (constant) [W/m k]
x,y and z: coordinates system [m]
u,v and w: velocity [m/s]
μ: Viscosity of air, (constant) [kg/m s]
the flow considered is turbulent flow for natural convection within a system equipped an inlet and an outlet.
regards
( μ/T) *
(∂v/∂z +∂w/∂y )^2 ]
(μ/T) *
(∂v/∂z +∂w/∂y )^2 ]
T: Temperature [k]
regards
Hello
Can someone tell me how to calculate a function as post-processed quantities:
( μ/T) *
(∂v/∂z +∂w/∂y )^2 ].
T: Temperature [k]
Or temperature gradients and velocity gradients of the field.
best regads.
Hakim.
( μ/T) *
T: Temperature [k]
best regads.
Hakim.
In versions 3.x you can find some interesting examples in cs_(f)_user_extra_operations-energy-balance.f90.
JF
JF
yes I know but I need a small illustrative example. is it possible for you to give me a small example in detai?
like A=(1/T²)*(dT/dX) +(1/T)*(du/dx).
Hakim.
Hakim.
I'd like to output this fonction as post-processed result on surface of symetry. can some one help me to do this?
or
A= (1/T²)*grad(T) * (1/T)*grad(U).
Hakim.
or
Hakim.
The dedicated subroutine to postpro quantities (fields, ...) on the mesh is cs_user_postprocess_var.f90.
Hi Yvan
I want if you can to check these subroutines for me, because even if it works properly I can't have a results that I wwant. However, if I change the name of the variable to be displayed, for example rtp (iel, ivar) or rtp (iel, iu) I get exactly the expected values.
Hakim
Hakim
- processus.tar.gz
- (527.89 KiB) Downloaded 224 times
