usvpst don't see the "ipart" variation
Posted: Tue Oct 08, 2013 4:05 pm
I defined an additional post-processing meshes (2 median planes "plan_z" and "plan_y") in "usdpst"
The problem is that "usvpst" don't see this variation of "ipart". When I print "ipart" in listing file I get "ipart= -1 or -2" !! although "nbpart" is set to 2 in "usdpst" !!
Any idea about that !!
nbcas = 1
do icas = 1, nbcas
do ii = 1, len(nomcas)
nomcas (II:II) = ' '
do ii = 1, len(nomrep)
nomrep (ii:ii) = ' '
do ii = 1, len(nomfmt)
nomfmt (ii:ii) = ' '
do ii = 1, len(optfmt)
optfmt (ii:ii) = ' '
if (icas .eq. 1) then
nomcas = 'chr'
nomrep = 'EnSight'
nomfmt = 'EnSight Gold'
optfmt = 'binary'
indmod = 0
ntchrl = 1
endif
nbpart = 2
do ipart = 1, nbpart
nlcel = 0
nlfac = 0
nlfbr = 0
do iel = 1, ncelet
lstcel(iel) = 0
do ifac = 1, nfac
lstfac(ifac) = 0
do ifac = 1, nfabor
lstfbr(ifac) = 0
do ii = 1, len(nommai)
nommai(ii:ii) = ' '
! Part 1: "plan Z"
if (ipart .eq. 1) then
nommai = 'Plan_z'
! Interior faces
call getfac('plane[0, 0, -1, 0.0445, epsilon = 0.0001]', nlfac, lstfac)
! Create post-processing mesh
call pstcma (ipart, nommai, nlcel, nlfac, nlfbr, lstcel, lstfac, lstfbr)
! Part 2: "plan Y"
elseif (ipart .eq. 2) then
nommai = 'Plan_y'
! Interior faces
call getfac('plane[0, -1, 0, 0.017, epsilon = 0.0001]', nlfac, lstfac)
end if
endif
if ((ipart .eq. 1) .or. (ipart .eq. 2)) then
! ! Associate post-processing meshes 1 and 2 with writers 1 and 2.
icas = 1
call pstass(ipart, icas)
endifCode: Select all
if (ipart.eq.1 .or. ipart.eq.2) then
! Initialize variable name
do ii = 1, 32
namevr (ii:ii) = ' '
! Variable name
namevr = 'Interpol pressure'
! Variable dimension (1: scalar, 3: vector, 6/9: symm/non-symm tensor)
idimt = 1
! Values are not interlaced (dimension 1 here, so no effect).
ientla = 0
iphas = 1 ! We only consider phase 1 in this example
! Variable number
ivar = ipr(iphas)
! Compute variable values on interior faces.
! we use a simple linear interpolation.
if(irangp.ge.0) then
call parcom (rtp(1,ivar))
endif
if(iperio.eq.1) then
idimte = 0
itenso = 0
call percom(idimte, itenso, &
rtp(1,ivar), rtp(1,ivar), rtp(1,ivar), &
rtp(1,ivar), rtp(1,ivar), rtp(1,ivar))
endif
do iloc = 1, nfacps
ifac = lstfac(iloc)
ii = ifacel(1, ifac)
jj = ifacel(2, ifac)
pond = ra(ipond-1+ifac)
trafac(iloc) = pond * rtp(ii, ivar) &
+ (1.d0 - pond) * rtp(jj, ivar)
! Compute variable values on boundary faces.
! In this example, we use a simple copy of the adjacent cell value.
! do iloc = 1, nfbrps
! ifac = lstfbr(iloc)
! ii = ifabor(ifac)
! trafbr(iloc) = rtp(ii, ivar)
! enddo
! Values are defined on the work array, not on the parent.
ivarpr = 0
! Output values
call psteva(ipart, namevr, idimt, ientla, ivarpr, &
ntcabs, ttcabs, tracel, trafac, trafbr)
endifBest regards
