cs-3.0 installation
Posted: Sat May 18, 2013 3:10 pm
by steph
hi
I installed Code_Saturne 3.0 from the command. / install_saturne.py (after completing the setup file) and I'd like to know if the installation was successful. I send you the attachment files and setup install_saturne.log
regards
Re: cs-3.0 installation
Posted: Mon May 20, 2013 5:08 pm
There is no specific tool to check your installation, though a few tests (such as building a case, compiling user subroutines, and running in parallel) may be mentioned in previous posts of this forum.
Once the install seems to have run OK, you just need to use the code to test it.
Posted: Tue May 21, 2013 10:30 am
by ddquang
Hi all,
I'm a newbie in Code_Saturne, i tried to install the version 3.0.1 and run a tutorial (case 1) to check if it is correctly run. And when i started the calculation, it stopped with an error message as following:
/usr/local/libexec/code_saturne/cs_solver: error while loading shared libraries: libsaturne.so.0: cannot open shared object file: No such file or directory
Error in calculation stage.
Any suggestion for me, please,
Thank so much
Posted: Tue May 21, 2013 4:48 pm
I believe I can answer this, even though providing more details as detailed in the forum recommendations is good practice:
As you installed the code under /usr/local, I assume you have root/sudo access on your machine.
In this case, after installing the code, run:
sudo ldconfig
(or log as root and run ldconfig)
The try again.
This occurs quite often, so I have to make a note to add a paragraph about this in the installation documentation...
