Reference temperature trefth
Posted: Wed May 15, 2013 8:34 am
I have a question regarding the above mentionned item. while activating the thermal model in celsius, the xml file shows a reference temperature in the xml file of 1273,15 as you can see hereafter :
<reference_values>
<pressure>101325</pressure>
<velocity>1</velocity>
<temperature>1273.15</temperature>
</reference_values>
But I read in the documentation that this temperature should be 298.15 if the reference temperature displayed in the xml file is the trefth. I don not know if this is normal or not. Can someone tells me if I am correct suggesting that this temperature should be 298.15 instead of 1273.15, and what can be the impacts ?
Thanks.
<reference_values>
</reference_values>
Thanks.
