User Subroutine Compilation Problem
senartcon
Post by senartcon »
Hello All,
I am trying to get a piece of subroutine for physical properties to work but getting runcase error. I am attaching my compile.log and my subroutine.
Previously I have tested Code_Saturne 2.3 and was able to run a TempC based variable density problem. But recently I installed Code_Saturne 3.0.1 on Ubuntu 12.04 and facing this issue.
Please point out my mistakes.
Anand
compile.log
(3.37 KiB) Downloaded 774 times
cs_user_physical_properties.f90
(10.44 KiB) Downloaded 810 times
Re: User Subroutine Compilation Problem
It seems the code is not able to re-link with libxml2. This is strange, ad if libxml2 is present upon install, it should be usable afterwards. So here a a few questions to help troubleshoting:
- does the code work correctly when not using a user subroutine ?
- did you perhaps uninstall libxml2 after installing Code_Saturne, or use a non-packaged version of libxml2 ?
- could you post your installation logs (especially the config.log file) for the Code_Saturne installer ?
senartcon
Post by senartcon »
-Yes, the code works correctly without User Subroutine. (tested for a laminar flow in channel)
-No, libxml2 was never un-installed and is the latest version: 2.7.8.dfsg-5.1ubuntu4.4
-I am attaching the insallation logs and also my installation setup
Anand
setup.txt
(4.62 KiB) Downloaded 747 times
config.log
(198.61 KiB) Downloaded 732 times
install_saturne.log
(1.55 MiB) Downloaded 756 times
I am not quite sure, but you seem to both have a packaged libxml2, and one from the installer (this should not be an issue, but could become one if there is a minor difference in link order between the install and the re-compilation script).
I would recommend:
- remove libxml2 from the /home/anand/Code_Saturne directories
- make sure you have the libxml2-dev Ubuntu package installed
- in your setup file, use:
libxml2 /usr yes no
- reinstall Code_Saturne
- re-test...
senartcon
Post by senartcon »
Thanks a lot Yvan,
The code compiles without error!!!
Anand
