Sigsegv error when preprocessing
Posted: Mon May 06, 2013 9:12 pm
by cyrillic
Hello I've made a very simple cgns mesh using ICEM, however during preprocessing a sisegv error message comes up and I can't work out why. Different cgns meshes for different cases work fine. I've remade the one I want to use in case I made a mistake the first time but it still didn't work. Could anyone enlighten me to my error?
The mesh is attached.
Cheers,
Stuart
  |   Code_Saturne Preprocessor  |
  ECS   version 2.0.1   (Tue 10 May 2011 12:11:53 BST)
  STAR-CCM+ file format support
  CGNS 2.5.4 file format support
  Reading of compressed files ('.gz') with Zlib 1.2.5
Case configuration
  Date                : Mon 06 May 2013 20:59:46 BST
  System              : Linux 2.6.37.1-1.2-desktop
  Machine             : mace-r-mbgnjsr9
  Processor           : Intel(R) Core(TM) i7 CPU         870  @ 2.93GHz
  Memory              : 4045888
  User                : stuart (Stuart Russant)
  Directory           : /home/stuart/Documents/Saturne/IMPINGE/TRIAL/RESU
  Case name           : check_mesh
  Mesh file           : /home/stuart/Documents/Saturne/IMPINGE/MESH/ImpingeTrial.cgns
Reading mesh from file in CGNS format
  Mesh file: /home/stuart/Documents/Saturne/IMPINGE/MESH/ImpingeTrial.cgns
  CGNS version       : 2.4
  Base name          : BASE#1
  Physical dimension : 3
  Cell dimension     : 3
  Number of zones    : 1
    Zone 1: "ImpingeTrial.uns"; type "Unstructured"
      597 vertices; 328 cells
      (cartesian coordinates, "RealDouble" precision, unit "Null")
      Section  1: "SOLID";
                   (indices 1 to 328, type "HEXA_8")
      Section  2: "WALL";
                   (indices 329 to 688, type "QUAD_4")
      Section  3: "WALL2";
                   (indices 689 to 692, type "QUAD_4")
      Section  4: "INLET";
                   (indices 693 to 696, type "QUAD_4")
      Section  5: "OUTLET";
                   (indices 697 to 792, type "QUAD_4")
  CGNS boundary condition information:
    Zone 1
      BC  1: "WALL" ("UserDefined" on "FaceCenter")
      BC  2: "WALL2" ("UserDefined" on "FaceCenter")
      BC  3: "INLET" ("UserDefined" on "FaceCenter")
      BC  4: "OUTLET" ("UserDefined" on "FaceCenter")
      BC  5: "GEOM" ("UserDefined" on "FaceCenter")
  Number of vertices                          :      597
  Number of faces                             :      464
  Number of cells                             :      328
  Group "WALL"
    Number of faces    :      360
  Group "WALL2"
    Number of faces    :        4
  Group "INLET"
    Number of faces    :        4
  Group "OUTLET"
    Number of faces    :       96
SIGSEGV signal (access to forbidden memory area) intercepted !
Call stack
1: 0x425bd2 (cs_preprocess)
2: 0x41bfad (cs_preprocess)
3: 0x417970 (cs_preprocess)
4: 0x7f7d0f152bfd (libc.so.6)
5: 0x411c89 (cs_preprocess)
Re: Sigsegv error when preprocessing
Posted: Mon May 06, 2013 11:25 pm
This seems like a familiar bug in ICEM (present in versions 13-14 at least).
ICEM exports no edges, but defines groups on edges not existing in the mesh, (which crashes the reader).
2 solutions:
- either use the cgnsview CGNS tool to edit the CGNS file and remove the offending group (relatively easy to spot).
- upgrade your version of Code_Saturne or at least its preprocessor to the latest bug-fix/portability release: newer versions of the code (ecs 2.0.3 for Code_Saturne 3.0, or Code_Saturne 3.0.x) detect this error by ICEM and work around it.
Posted: Fri May 17, 2013 2:45 pm
by cyrillic
This solved it thanks. I used Fluent to remake the cgns mesh.
