Compilation issue with lecamx
Posted: Thu Apr 25, 2013 11:07 am
by Support TGCC
I'm a member of the support applicative team of TGCC (http://www-hpc.cea.fr/fr/complexe/tgcc.htm). When we installed saturne/3.0.0 on cluster, some errors occur.
$ ./configure --prefix=[..]/saturne-3.0.0 CC=icc CXX=icpc FC=ifort --with-hdf5=[...]/hdf5-1.8.8 LDFLAGS="$CCC_HDF5_LDFLAGS" --with-blas-type=MKL --with-blas-lib="${MKL_LIB_DIR}" --with-blas-libs="-lmkl_rt -liomp5 -lm" --with-blas-include="${MKL_INC_DIR}" --with-hdf5=/usr/local/hdf5-1.8.8 --with-mpi="${MPI_ROOT}" --with-mpi-exec="${MPI_ROOT}/bin" --with-mpi-include="${MPI_ROOT}/include" --with-mpi-lib="${MPI_ROOT}/lib" --enable-openmp --enable-mpi
$ make -j 16
make[3]: Entering directory `[..]/code_saturne-3.0.0/src/base'
/bin/sh ../../libtool --tag=FC --mode=compile ifort -I../../src -I../../src/atmo -I../../src/cfbl -I../../src/cogz -I../../src/comb -I../../src/cplv -I../../src/ctwr -I../../src/elec -I../../src/lagr -I../../src/pprt -I../../src/rayt -O2 -cpp -fpic -warn -diag-disable 7712 -openmp -c -o lecamo.lo lecamo.f90
libtool: compile: ifort -I../../src -I../../src/atmo -I../../src/cfbl -I../../src/cogz -I../../src/comb -I../../src/cplv -I../../src/ctwr -I../../src/elec -I../../src/lagr -I../../src/pprt -I../../src/rayt -O2 -cpp -fpic -warn -diag-disable 7712 -openmp -c lecamo.f90 -fPIC -o .libs/lecamo.o
lecamo.f90(133): error #6784: The number of actual arguments cannot be greater than the number of dummy arguments. [LECAMX]
call lecamx &
compilation aborted for lecamo.f90 (code 1) make[3]: *** [lecamo.lo] Error 1 make[3]: Leaving directory `[..]/code_saturne-3.0.0/src/base' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `[..]/code_saturne-3.0.0/src' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `[..]/code_saturne-3.0.0'
make: *** [all] Error 2
There is a difference between the call of lecamx subroutine in lecamo.f90 and his its definition in lecamx.f90. We fixed it by :
$ diff -y lecamo.f90 lecamo.f90.old
call lecamx & call lecamx &
( ndim , ncelet , ncel , nfac , nfabor , & ( ndim , ncelet , ncel , nfac , nfabor , &
nnod , nvar , nscal , & nnod , nvar , nscal , &
dt , rtp , propce , propfa , propfb , & dt , rtp , propce , propfa , propfb , &
coefa , coefb , frcxt ) | coefa , coefb , frcxt , prhyd )
endif endif
Greetings,
Jérôme Esbrat
Re: Compilation issue with lecamx
Posted: Thu Apr 25, 2013 1:05 pm
Thanks for the feedback and the fix (it seems that when building even with icc on some of our clusters, we missed this).
The fix has been commited to both the developpement trunk and the version 3.0 maintenance branch, and will be available in bug-fix version 3.0.1, which we intend to release no later than the end of next week (and maybe earlier).
Thanks again,
