I have a problem with code_satrune installatio. I certainly missed something during instalaltion, because when I use the check mesh option in CS3_rc1, I have this message :
Erreur a l'exécution du préprocesseur
ecs_cmd.c:563: Erreur fatale.
MED output format not available in this build.
Pile d'appels
1: 0x4071a5 (cs_preprocess)
2: 0x4047b2 (cs_preprocess)
3: 0x7f783b01d76d (libc.so.6)
4: 0x404fa1 (cs_preprocess)
Fin de la pile
I do not have strong competences in linux, and would like to know if someone can help me to understand where I failed during CS3_rc1 installation. Thanks.
my config :
Code saturne 3 rc1
Kubuntu12.04
Fred.
CS3 : MED output format not available in this build.
Fred
Xubuntu 16.04 / CS5.0
Re: CS3 : MED output format not available in this build.
Hello further information : I installed some of the missing libraries, and this partially solved the problem. i am facing now a problem during installation of MED :
///opt/CS_3/hdf5-1.8.9/include/H5public.h
checking HDF version is ok... yes
yes
checking for H5open in -lhdf5... no
configure: error: either use HDF5HOME env. var. or --with-hdf5=<path>
here is the config.log of the MED install.
Can someone help me ? Thks
yes
- config.log
- (21.5 KiB) Downloaded 780 times
Fred
OK, that was tricky, and I am even not sure how i solved the problem. Actually I still have the virtual machine which I used to make simulations before, this was coming from the livecd CAELinux. I noted all the different packages installed relative to MED, CGNS, HDF5, MPI and I installed them back on the current computer which is now on Kubuntu 12.04 64bits. I launch the installer again, and this seems to correctly follow the installation process now, at least I passed the configure error when installing the med package. This is not really scientific, but I am quite new to linux, and command line has never been of a big interest since last year... Sorry for this lack of accuracy for the one who will meet the same problem I faced, these are the only guidelines I can give.
Fred
Unfortunately I still have the problem that none of the check mesh otion is operating. each time I have an error message "MED output format not available in this build", or CGNS if I ask for CGNS. I am then not able to run a preproc. I overcome the problem of med file installations, CGNS MPI, HDF5 installtion worked properly, I re-run the code saturne configure-compile-install procedure to be sure. But still have the problem. Does some have an idea, because i am short of it right now. Thanks a lot.
Fred
Could you post the latest version of your config.log (it may be different from the one you posted before) ?
Thanks for your answer. Here is the new config log of the Code_Saturne installation. If you need any other config. log of the rest of installation, let me know. Any help will be welcome.
- config.log
- (210.66 KiB) Downloaded 773 times
Fred
It seems you just ran "configure" without any options in the source directory. You need to add options such as --with-med=<path> to tell the build system where to find the matching library. In addition, it is recommended to use a seaprate build directory.
All recomendations are provided in the installation guide (only the beginning chapters really need to be read; the rest are examples): http://code-saturne.org/cms/documentati ... stallation
Thanks for your help, this is off course the case. Sorry to be a pain... My linux knowledge is limited so far. I am learning but not as fast as I wish.
Now the check mesh procedure is OK, nevertheless at the end of the file "run mesh quality criteria"
/usr/local/libexec/code_saturne/cs_solver: error while loading shared libraries: libsaturne.so.0: cannot open shared object file: No such file or directory
I check the file in consideration libsaturne.so.0 is in /usr/local/lib which is the appropriate place it seems. i do not know if this will affect the rest of the process.
Fred
If you installed Code_Saturne in /usr or /usr/local (the default if you do not specify --prefix to the installer), you may need to run:
ldconfig
as root (or sudo ldconfing it there is no root account, such as on Ubuntu-based systems or similar).
Does it help ?
ldconfig
Does it help ?
Wonderfull ! Thanks for your help Yvan. this is working fine. This issue is solved.
Fred
