How to set the "Periodic Boundary Conditions"?
Posted: Wed Jan 30, 2013 5:12 am
by yhuang
Hi, everyone
How to set the "Periodic Boundary Conditions" for 2.0?
Thank you very much!
Yuan huang
Re: How to set the "Periodic Boundary Conditions"?
Posted: Mon Feb 04, 2013 11:00 am
by JamesMcNaughton
Hi Yuan,
There is an example of how to do it with the GUI at the tutorial here -
http://cfd.mace.manchester.ac.uk/twiki/ ... leTutorial
Hope that helps!
James
Posted: Fri Feb 22, 2013 4:47 am
by yhuang
Hi, James
Thanks very much, but how to do this without GUI?
Yuan Huang
Posted: Sat Feb 23, 2013 2:26 am
Defining periodicity without the GUI in version 2.0 is described in the user manual. Just search the pdf for "periodicity".
Posted: Thu Feb 28, 2013 12:39 pm
by yhuang
Hi, Yvan
I preprocess the mesh by command "cs_preprocess -m meshname --rota --angle --dir dx dy dz ----invpt x y z --group groupname", and then set "COMMAND PERIO=1", "EXEC PREPROCESS=no" in the runcase.
Is that correct?
Thanks very much!
Yuan Huang
Posted: Thu Feb 28, 2013 7:26 pm
No, you need to set EXEC_PREPROCESS=yes if you want preprocessing.
But you don't need to edit the runcase for this: the GUI will do it for you.
Posted: Fri Mar 01, 2013 1:18 pm
by yhuang
hi,
I am really confused. If set EXEC_PREPROCESS=yes, how to use the preprocess get by the command "cs_preprocess -m meshname --rota --angle --dir dx dy dz ----invpt x y z --group groupname"?
And you said the GUI will do it, but the question is I don't use the GUI?
Can you tell the details?
Thanks very much!
Yuan Huang
Posted: Fri Mar 01, 2013 9:02 pm
I did not realize that you ran the preprocessor first, then used the preprocessor_output file in the script. In that case, setting EXEC_PREPROCESS=no is okay.
When you run the preprocessor, it can output postprocessing files (viewable with ParaView, EnSight, or SALOME for example) to show you what periodicity was built and where the remaining boundaries are.
All the details are in the user documentation (search the pdf for "periodicity").
And why don't you use the GUI ?
Posted: Sat Mar 02, 2013 1:59 pm
by yhuang
Because the case I simulated is about combustion, and I GUI don't support it.
Yuan Huang
Posted: Sat Mar 02, 2013 5:41 pm
The GUI does not support combustion setup in V2.0, but it still supports preprocessing, and you can mix the GUI and user subroutines: user subroutines have priority.
If this causes issues, at least, prepare all preprocessing with the GUI, and just set PARAM= in the runcase.
