problem of mesh
yhuang
problem of mesh
Post by yhuang »
Hi, everyone
How to do when the domain is composed of two separate meshes without the Graphical User Interface?
Another question is about preprocessing. When I preprocess a case with 25million cells, there is error and it looks like the memory is not enough.
I want to run in parallel, if the preprocessing is no error, the memory should be enough when it be running. How to handle this?
Can the mesh be preprocessed in parallel?
Can the mesh be preprocessed in another PC with bigger memory and copy the file of preprocessing to run, How to do this?
thank you very much!
Yuan Huang
Re: problem of mesh
The answers depend on this:
http://code-saturne.org/forum/viewtopic.php?f=2&t=7
