Hi everybody,
I am using Code_Saturne 2.2.2 with activated ALE. For a post-processing need, with ancient versions (like 1.3 !!), I used to put the keyword 'ICHRMD' to 10 in order to obtain output files with fixed mesh but with the "chr.displacement.****" files.
With the new versions, as this keyword is no more implemented, I don't know how to obtain post-processing files which would have a "results.displacement.****" form, except by using the routine usvpst.f90.
Is there another way to do this ? And, if not, do I have to construct a nnod*3 vector which would contain "depale" in usvpst ?
Many thanks for any help,
Marie
results.displacement.**** files
Re: results.displacement.**** files
For versions 2.3 and 3.0, the output if this field is automatic.
For version 2.2, there is a missing test for ALE and call to pstdfm in the modini subroutine, but if you simply add
anywhere in usdpst or usini1, things should work (we have to remember to fix this bug in the next 2.2 bugfix release).
call pstdfmRegards,
pomarede
Many thanks, I'll try this and then, upgrade my version
pomarede
It works
I finally added
in cs_user_parameters.f90, in the usipes routine.
Thanks again Yvan,
Marie
I finally added
call pstdfmThanks again Yvan,
Marie
