Code_Saturne 2.0.3 : programming problem
SAGUEDONG
Post by SAGUEDONG »
I generate a text file and I would like please to know how to take the Code_Saturne the account in his calculations.
I use the command:
open(10, file=' name of file.txt' )
write(10,*) ........
to generate the file and it is created without problems.
But when I use : open(10,file='name of file.txt') ,
read(10,*) .......
Saturne return an error.
how can I do to resolve it?
Ines SAGUEDONG
Re: Code_Saturne 2.0.3 : programming problem
I have an idea of what could be going wrong, but if you do not post your error message first, I cannot be sure of the cause, and could give you a wrong explanation, so please follow the forum posting recommendations relative to description of problems if you want to avoid needless iterations.
SAGUEDONG
Post by SAGUEDONG »
Hello!
yes the error is:
Parallel Code_Saturne with partitioning in 2 sub-domains
Code_Saturne is running
/home/saguedong/tmp_Saturne/INES2.CAS2.10151425
Kernel version: /home/saturne/opt/cs-2.0
Preprocessor: /home/saturne/opt/cs-2.0/bin
Preparing calculation
Starting calculation
At line 1383 of file /home/saguedong/tmp_Saturne/INES2.CAS2.10151425/src_saturne/ustssc.f90 (unit = 10, file = 'ines.txt')
Fortran runtime error: End of file
mpirun has exited due to process rank 1 with PID 2332 on
node saguedong-EasyNote-TK85 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
Check Kernel log (listing) and error* files for details
Error in calculation stage.
Tank you
Ines
Did you copy the original file in your DATA directory ? With version 2.0, you also need to add the file to the list of user files (under the GUI, "Calculation management/Prepare batch calculation/User files, or directly in the runcase, under USER_INPUT_FILES).
SAGUEDONG
Post by SAGUEDONG »
Hello!
Tank you Yvan for your help.
Ines Saguedong
