[solved] make fails for 2.3.1 and nightly version
Posted: Sun Sep 02, 2012 4:13 pm
when installing, I receive the error messages below (Ubuntu 12.04 for the cs version 2.3.1 as well as for the night version). Since there were a couple of libs missing (med, scotch, cgns), I sourced med from my code_aster installation (salome didn't work) and scotch and cgns from my salome installation. Thus
make stops with the following errors:
Any ideas?
al
./configure --prefix=/home/alain/bin/saturne --with-scotch=/home/alain/bin/salome/Salome-V6_5_0p1-LGPL-x86_64/prerequisites/Scotch_5111 --with-cgns=/home/alain/bin/salome/Salome-V6_5_0p1-LGPL-x86_64/prerequisites/Cgnslib_3134 --with-salome=/home/alain/bin/salome/Salome-V6_5_0p1-LGPL-x86_64 --with-med=/home/alain/bin/aster/public/med-3.0.5
fvm_to_medcoupling.cxx:1781:1: warning: unused parameter 'path' [-Wunused-parameter]
fvm_to_medcoupling.cxx:1781:1: warning: unused parameter 'options' [-Wunused-parameter]
fvm_to_medcoupling.cxx:1894:1: warning: unused parameter 'time_step' [-Wunused-parameter]
fvm_to_medcoupling.cxx:1894:1: warning: unused parameter 'time_value' [-Wunused-parameter]
fvm_to_medcoupling.cxx: In function 'void fvm_to_medcoupling_export_nodal(void*, const fvm_nodal_t*)':
fvm_to_medcoupling.cxx:2002:38: error: '_write_connect_block' was not declared in this scope
fvm_to_medcoupling.cxx: In function 'void fvm_to_medcoupling_export_field(void*, const fvm_nodal_t*, const char*, fvm_writer_var_loc_t, int, cs_interlace_t, int, const cs_lnum_t*, cs_datatype_t, int, double, const void* const*)':
fvm_to_medcoupling.cxx:2095:8: warning: unused variable 'output_dim' [-Wunused-variable]
fvm_to_medcoupling.cxx:2101:14: warning: unused variable 'rank' [-Wunused-variable]
fvm_to_medcoupling.cxx: At global scope:
fvm_to_medcoupling.cxx:231:1: warning: 'INTERP_KERNEL::NormalizedCellType _get_norm_elt_type(fvm_element_t)' defined but not used [-Wunused-function]
fvm_to_medcoupling.cxx:296:1: warning: 'void _get_vertex_order(INTERP_KERNEL::NormalizedCellType, int*)' defined but not used [-Wunused-function]
make[3]: *** [fvm_medcoupling_la-fvm_to_medcoupling.lo] Error 1
make[3]: Leaving directory `/home/alain/bin/code_saturne-2.3.1/src/fvm'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/alain/bin/code_saturne-2.3.1/src'
make[1]: Leaving directory `/home/alain/bin/code_saturne-2.3.1'
make: *** [all] Error 2al
