Hi
I tried the compressible mode in the GUI (thanks for the addition!) but the calculation stopped with:
@ @@ WARNING: stop in data input for compressible flow
@ The user subroutine 'uscfx2' must be completed
@ The calculation will not be run.
It is expected that uscfx2.f90 has to be put for compilation or is it a small bug in this early version?
Thanks in advance
Code Saturne 2.3.1: compressible mode in GUI question
Jacques Fontaine
Re: Code Saturne 2.3.1: compressible mode in GUI question
The compressible module is experimental. I am not a specialist (and the referent for this module is on holiday) but I think you can not run a compressible case without user subroutines, you can activate the physic in the GUI but you must also complete uscfx2 (in cs_user_parameters).
