Joining meshes problems
Posted: Fri Jul 13, 2012 3:53 pm
by DH07120S
CS version 2.2.1
I have some meshes that I want to join in CS so I import all of them and I set all the joining faces but it's not work. I try with all the parameters for fraction and plane.
So I try it in CS 2.0.5 and it's work.
I import the preprocessor_ouput mesh and I put it in the version 2.2.1 by using "Use existing mesh input". I check and it works. But when I want to import the boundaries conditions it's not possible.
In conclusion, the two main problem : joining meshes and importing boundaries in version 2.2.1
Re: Joining meshes problems
Posted: Fri Jul 13, 2012 3:56 pm
by DH07120S
I forgot something.
After lauching the calculation I must use the core partitionning : Morton curve (box)
Posted: Fri Jul 13, 2012 4:13 pm
by Jacques Fontaine
Depending on the size of meshes, could you post your meshes on the forum or on a FTP?
About boundary conditions, what do you mean by "you can't import BCs"?
JF
Posted: Mon Jul 16, 2012 8:47 am
Could you at least post some "minor" details such as your "listing" file for the case that fails, as per the Forum recommendations ?
Posted: Wed Sep 12, 2012 11:49 am
by flyer
hello,
the problem which i have with the 2.2.2 version is defined below (from a listing file).
i used the same meshes withe c_s 2.0.5 and it works correctly,
best regards:
Première face avec une mauvaise définition de conditions aux limites
(sur 640)
a une condition aux limites de type 0, un centre (-2.86894, -2.78705, 0.5)
/home/bekhti/programmes/cs_2.2.2/installer/code_saturne-2.2.2/src/base/cs_boundary_conditions.c:408: Erreur fatale.
Certaines définitions de conditions aux limites sont incomplètes
ou incorrectes :
Pour plus de détails, vérifiez la fin du "listing" de calcul,
ou visualisez le post traitement dédié aux erreurs.
Posted: Thu Sep 13, 2012 12:09 am
Did you visualize the error region post-processing output ? The difference is probably due to slightly different handling of tolerances, which means small faces merged in one version might not be merged in another version. To avoid this, you may try to slightly increase the joining tolerance factor for joining.
I do not know what your mesh is, but I could guess that you have two curved surfaces (such as cylinders) with different mesh sizes. If this is the case, unmerged faces are equivalent to a small "ridge", for which you could apply wall boundary conditions.
In any case, use visualization (both of mesh groups in quality/preprocessing mode and of boundary condition errors) to assist your understanding of the problem and the choice of a good solution.
Posted: Thu Sep 13, 2012 11:07 am
by flyer
hello,
thank you mr. fournier, it work now with a small increase of a joining factor.
my best thanks.
