installation Salome+CS+Syrthes via VM on ubuntu 15.10
jgd23
Re: installation Salome+CS+Syrthes via VM on ubuntu 15.10
Post by jgd23 »
What do you think about my install now? It's ok or not?
I am very interested in using code saturne and Syrthes in a coupled way
Julien
Did you use the ".syd" Syrthes setup from the tutorial examples, or recreate it from the tutorial description ? Other users have had issues with this, and the tutorial has nor been updated yet, but you can find recent threads on this forum relating to this.
jgd23
Post by jgd23 »
I use .syd from the example folder from code saturne installation pack.
To be clear, which files I need to run this coupled study?
I need 3 folders:
- one fluid: within it DATA RESU SCRIPTS SRC folders, in the DATA folder the
fluid-3rond2D-coupling.xml file with associated mesh dependancy.
- one solid: within it the solid-coupling.syd file with associated mesh dependancy and others
- one RESU_COUPLING. (empty)
- the file coupling_parameters.py:
domains = [
{'solver': 'Code_Saturne',
'domain': 'fluid',
'script': 'runcase',
'n_procs_weight': None,
'n_procs_min': 1,
'n_procs_max': None}
{'solver': 'SYRTHES',
'domain': 'solid',
'script': 'solid-coupling.syd',
'n_procs_min': 1,
'n_procs_max': None,
'opt' : '-v med'}
- the runcase_coupling file
#!/bin/bash
export PATH=/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin:$PATH
# Run command:
\code_saturne run --coupling coupling_parameters.py
After launching the runcase_coupling file there is in the terminal:
Coupling execution between:
o Code_Saturne [1 domain(s)];
o SYRTHES [1 domain(s)];
Code_Saturne is running
Version: 4.0
Path: /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64
Result directory:
/home/julien/3disks2D/newtest/4-2Ddisks/case1/RESU_COUPLING/20160708-1124
Single processor SYRTHES simulation.
Preparing calculation data
SYRTHES4 home directory: /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64
MPI home directory: /usr
Building the executable file syrthes..
***** SYRTHES compilation and link completed *****
Preprocessing calculation
SyrthesCase summary:
Name = solid
Data file = solid-coupling.syd
Update Data file = True
Do preprocessing = True
Debug = False
Case dir. = /home/julien/3disks2D/newtest/4-2Ddisks/case1/solid
Execution dir. = /home/julien/3disks2D/newtest/4-2Ddisks/case1/RESU_COUPLING/20160708-1124/solid
Data dir. = /home/julien/3disks2D/newtest/4-2Ddisks/case1/RESU_COUPLING/20160708-1124/solid
Source dir. = /home/julien/3disks2D/newtest/4-2Ddisks/case1/RESU_COUPLING/20160708-1124/solid/src
Post dir. = /home/julien/3disks2D/newtest/4-2Ddisks/case1/RESU_COUPLING/20160708-1124/solid/POST
Conduction mesh dir. = /home/julien/3disks2D/newtest/4-2Ddisks/case1/solid/
Conduction mesh name = 3rond2d.syr
Total num. of processes = 1
Logfile name = syrthes.log
Echo = True
Parallel run = False
SyrthesParam summary
Param file name = solid-coupling.syd
Radiation mesh name = None
Result prefix. = resu2
Restart = False
Coupling = True
Interpreted functions = False
Start SYRTHES preprocessing
Updating the mesh file name..
-> OK
Starting calculation
with errorcode 1.
mpiexec.openmpi noticed that process rank 0 with PID 1822 on node julien-VirtualBox exited on signal 11 (Segmentation fault).
solver script exited with status 139.
Either Code_Saturne or SYRTHES may have failed.
Check Code_Saturne log (listing) and SYRTHES log (syrthes.log)
Saving calculation results
Post-processing..
.syrthes --> med..
--> /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4med30 -m "/home/julien/3disks2D/newtest/4-2Ddisks/case1/solid/3rond2d.syr" -r "/home/julien/3disks2D/newtest/4-2Ddisks/case1/RESU_COUPLING/20160708-1124/solid/resu2.res" -o "resu2.med"
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin/code_saturne", line 76, in <module>
retcode = cs.execute()
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 88, in execute
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 150, in run
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_run.py", line 304, in main
save_results=save_results)
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1779, in run
self.save_results()
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1694, in save_results
d.copy_results()
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case_domain.py", line 1200, in copy_results
raise RunCaseError(err_str)
cs_case_domain.RunCaseError:
Error during SYRTHES postprocessing
See also listing and syrthes.log files
Julien
syrthes.log
(7.06 KiB) Downloaded 629 times
listing.txt
(28.47 KiB) Downloaded 674 times
It is hard to tell what is wrong from the listing, as the computation seems to start OK (so the files seem to be in the right place).
Could you post the results of "ldd cs_solver" and "ldd syrthes.exe" in "/home/julien/3disks2D/newtest/4-2Ddisks/case1/RESU_COUPLING/20160708-1138/fluid" and "/home/julien/3disks2D/newtest/4-2Ddisks/case1/RESU_COUPLING/20160708-1124/solid" respectively ?
jgd23
Post by jgd23 »
I don't have these files!
In fluid, I have the files:
- error
- fluid_3disks_alone.xml
- fluid-3rond2D-coupling.xml
- listing
- mesh_input
- performance.log
- preprocessor.log
- setup.log
- and a folder: posprocessing
In solid:
- 3rond2d.des
- compile.log
- domaine.case
- domaine.geom
- listing.pak
- Makefile
- resu1_all.res
- resu1_all.syr
- resu2.add
- resu2_cplcd.syr
- solid-alone.syd
- solid-coupling.syd
- solid-coupling_restart.syd
- stderr.txt
- stdout.txt
- syrthes
- syrthes.log
- syrthes.stop
- tmp.data
- 2 folders: POST and src
Julien
OK, you can run "ldd syrthes" in solid, and for fluid, check the "cs_solver" path inside the run_solver file in the directory containing "fluid" and "solid", and run ldd on that path.
jgd23
Post by jgd23 »
I run "ldd syrthes" the solid folder:
julien@julien-VirtualBox:~/3disks2D/newtest/4-2Ddisks/case1/solid$ ldd syrthes
linux-vdso.so.1 => (0x00007ffc90bef000)
/usr/lib/x86_64-linux-gnu/libgfortran.so.3 (0x00007fcd2459f000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fcd2426d000)
libple.so.1 => /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/libple.so.1 (0x00007fcd2405b000)
libmpi.so.1 => /usr/lib/libmpi.so.1 (0x00007fcd23cd5000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fcd23ab6000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fcd236ec000)
libquadmath.so.0 => /usr/lib/x86_64-linux-gnu/libquadmath.so.0 (0x00007fcd234ad000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fcd23295000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007fcd23092000)
libhwloc.so.5 => /usr/lib/x86_64-linux-gnu/libhwloc.so.5 (0x00007fcd22e49000)
libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7 (0x00007fcd22c3e000)
/lib64/ld-linux-x86-64.so.2 (0x00005642f636d000)
libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007fcd22a33000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fcd2282e000)
In the runcase_coupling file, CS path is ok:
I am not sure to understand the last step that you told me to do.
I run "ldd $PATH" in the folder where there are solid and fluid folders:
ldd: /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin:/home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games: Aucun fichier ou dossier de ce type
or "ldd /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin" in the same folder, I have:
julien@julien-VirtualBox:~/3disks2D/newtest/4-2Ddisks/case1$ ldd /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin
ldd: /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin: n'est pas un fichier régulier
I hope I have done what you wanted
Julien
The second ldd should be:
ldd /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/libexec/code_saturne/cs_solver.
jgd23
Post by jgd23 »
In the folder with both fluid and solid, I run
"ldd /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/libexec/code_saturne/cs_solver"
The terminal returns:
julien@julien-VirtualBox:~/3disks2D$ ldd /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/libexec/code_saturne/cs_solver
linux-vdso.so.1 => (0x00007ffe6f14a000)
/usr/lib/x86_64-linux-gnu/libgfortran.so.3 (0x00007fb391114000)
libsaturne.so.0 => /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/libsaturne.so.0 (0x00007fb38f752000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fb38f50b000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fb38f140000)
libquadmath.so.0 => /usr/lib/x86_64-linux-gnu/libquadmath.so.0 (0x00007fb38ef01000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fb38ebf9000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fb38e9e1000)
libple.so.1 => /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/libple.so.1 (0x00007fb38e7cf000)
libmedC.so.1 => /home/julien/salome/Salome-V7_6_0-x86_64/tools/Medfichier-308/lib/libmedC.so.1 (0x00007fb38e55e000)
libxml2.so.2 => /usr/local/lib/libxml2.so.2 (0x00007fb38e1f8000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fb38dff4000)
libmpi.so.1 => /usr/lib/libmpi.so.1 (0x00007fb38dc6d000)
/lib64/ld-linux-x86-64.so.2 (0x0000557f6f8c4000)
libhdf5.so.7.4.0 => /home/julien/salome/Salome-V7_6_0-x86_64/prerequisites/Hdf5-1810/lib/libhdf5.so.7.4.0 (0x00007fb38d7b0000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fb38d42d000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fb38d213000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007fb38d010000)
libhwloc.so.5 => /usr/lib/x86_64-linux-gnu/libhwloc.so.5 (0x00007fb38cdc6000)
libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7 (0x00007fb38cbbc000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fb38c9b4000)
libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007fb38c7a8000)
What sould I do now?
Julien
So, the MPI libraries seem to be the same and OK.
From your other logs, it is Syrthes which is crashing, but I don't know why. Based on your syrthes.log file, in the "solid" directory (where the syrthes executable is found), could you try:
addr2line -e syrthes 0x4196eb
addr2line -e syrthes 0x4103fe
addr2line -e syrthes 0x4080c8
addr2line -e syrthes 0x402ce2
