Did you define boundary conditions based on the tutorial description, or use the example file already present ? There is missing info in the text, so starting from the file should work better (though it is less instructive).
installation Salome+CS+Syrthes via VM on ubuntu 15.10
Re: installation Salome+CS+Syrthes via VM on ubuntu 15.10
The first part of 3disk2d tutorial works with CS and Syrthes in stand alone mode.
I don't understand which files I need to run the coupled calculation of CS and Syrthes.
I don't understand which file I have to use for CS? I try to put in this directory the file in the SCRIPTS or DATA from the fluid folder of CS but I have errors...
I have in the same folder the following files:
- solid.syd (configuration for a coupled study),
- a runcase file :
#!/bin/bash
export PATH=/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin:$PATH
# Run command:
\code_saturne run --coupling coupling_parameters.py
- a py file named coupling_parameters.py:
# Define coupled domains
domains = [
{'solver': 'Code_Saturne',
'domain': 'fluid',
'script': 'runcase',
'n_procs_weight': None,
'n_procs_min': 1,
'n_procs_max': 1}
{'solver': 'SYRTHES',
'domain': 'solid',
'script': 'solid.syd',
'n_procs_min': 1,
'n_procs_max': 1,
'opt' : '-v ens'} # Additional SYRTHES options
# (ex.: postprocessing with '-v ens' or '-v med')
This is the terminal error message:
julien@julien-VirtualBox:~/3disks2D$ ./runcase
Coupling execution between:
o Code_Saturne [1 domain(s)];
o SYRTHES [1 domain(s)];
Code_Saturne is running
Version: 4.0
Path: /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64
Result directory:
/home/julien/3disks2D/RESU_COUPLING/20160704-1656
Single processor SYRTHES simulation.
Preparing calculation data
SYRTHES4 home directory: /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64
MPI home directory: /home/julien/Syrthes/syrthes4.3.0/extern-libraries/opt/openmpi-1.8.3/arch/Linux_x86_64
Building the executable file syrthes..
***** SYRTHES compilation and link completed *****
Preprocessing calculation
SyrthesCase summary:
Name = solid
Data file = solid-alone.syd
Update Data file = True
Do preprocessing = True
Debug = False
Case dir. = /home/julien/3disks2D/solid
Execution dir. = /home/julien/3disks2D/RESU_COUPLING/20160704-1656/solid
Data dir. = /home/julien/3disks2D/RESU_COUPLING/20160704-1656/solid
Source dir. = /home/julien/3disks2D/RESU_COUPLING/20160704-1656/solid/src
Post dir. = /home/julien/3disks2D/RESU_COUPLING/20160704-1656/solid/POST
Conduction mesh dir. = /home/julien/3disks2D/MESH
Conduction mesh name = 3rond2d.syr
Total num. of processes = 1
Logfile name = syrthes.log
Echo = True
Parallel run = False
SyrthesParam summary
Param file name = solid-alone.syd
Conduction mesh name = /home/julien/3disks2D/MESH/3rond2d.syr
Radiation mesh name = None
Result prefix. = resu1
Restart = False
Coupling = True
Interpreted functions = False
Start SYRTHES preprocessing
Updating the mesh file name..
-> OK
Starting calculation
[julien-VirtualBox:11086] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file ess_env_module.c at line 367
[julien-VirtualBox:11084] tcp_peer_recv_connect_ack: invalid header type: 946143232
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpiexec detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[14437,1],0]
Exit code: 1
Either Code_Saturne or SYRTHES may have failed.
Check Code_Saturne log (listing) and SYRTHES log (syrthes.log)
Saving calculation results
Post-processing..
.syrthes (.res) --> ensight...
--> /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4ensight -m "/home/julien/3disks2D/MESH/3rond2d.syr" -r "/home/julien/3disks2D/RESU_COUPLING/20160704-1656/solid/resu1.res" -o "resu1"
.syrthes (.rdt) --> ensight...
--> /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4ensight -m "/home/julien/3disks2D/MESH/3rond2d.syr" -r "/home/julien/3disks2D/RESU_COUPLING/20160704-1656/solid/resu1.rdt" -o "resu1_rdt"
Error in calculation stage.
Julien
- a runcase file :
#!/bin/bash
# Run command:
domains = [
'domain': 'fluid',
'n_procs_min': 1,
'n_procs_max': 1}
'domain': 'solid',
'n_procs_min': 1,
'n_procs_max': 1,
Version: 4.0
Result directory:
Name = solid
Debug = False
Echo = True
Restart = False
Coupling = True
-> OK
Exit code: 1
Post-processing..
Julien
At this stage, the install is probably OK, but there may be an error in your setup.
Did you read the recommended log files ?
I don't know how to find these log files?
In the repertory RESU_COUPLING a created directory is here with new fluid and solid directories.
In the solid directory there is syrthes.log file telling that everything is normal, the same for the listing.bak file.
In the fluid directory, I have only 3 files; the xml file (I think), the mesh input file and the preprocessor.log file which indicate that everything is normal. I think that Code Saturne case definition is not well set up in the parent folder.
What files are supposed to exist to realize the coupling in the parent folder?
Julien
Julien
You still have strange message in the script.
Did you use the same MPI library for Code_Saturne and Syrthes ?
No I used a different MPI for Syrthes. I modify the setup.ini like this:
mpi USE=yes PATH=/usr/bin
During installation I have the following message in the terminal:
Installation of syrthesmpi on architecture Linux_x86_64
mkdir: opérande manquant
Saisissez « mkdir --help » pour plus d'informations.
make -I /home/julien/Syrthes/syrthes4.3.0 -C ./syrthes-kernel/src clean
make[1]: Entering directory '/home/julien/Syrthes/syrthes4.3.0/src/syrthes-kernel/src'
rm -rf /home/julien/Syrthes/syrthes4.3.0/build//*.o
make[1]: Leaving directory '/home/julien/Syrthes/syrthes4.3.0/src/syrthes-kernel/src'
/usr/bin/bin/mpicc -c -O3 -D _FILE_OFFSET_BITS=64 -D_SYRTHES_MPI_ -I/home/julien/Syrthes/syrthes4.3.0/src/syrthes-kernel/include -I/home/julien/Syrthes/syrthes4.3.0/src/syrthes-kernel/lib_material_syrthes utilitaire.c -o /home/julien/Syrthes/syrthes4.3.0/build//utilitaire.o
make[1]: /usr/bin/bin/mpicc: commande introuvable
Makefile:22: recipe for target '/home/julien/Syrthes/syrthes4.3.0/build//utilitaire.o' failed
make[1]: *** [/home/julien/Syrthes/syrthes4.3.0/build//utilitaire.o] Error 127
Makefile:27: recipe for target 'syrthesmpi' failed
make: *** [syrthesmpi] Error 2
mv: impossible d'évaluer «/home/julien/Syrthes/syrthes4.3.0/build/*»: Aucun fichier ou dossier de ce type
Installation of syrthescfd on architecture Linux_x86_64
make CFD=yes -I /home/julien/Syrthes/syrthes4.3.0 -C ./syrthes-kernel/src clean
/usr/bin/bin/mpicc -c -O3 -D _FILE_OFFSET_BITS=64 -D_SYRTHES_MPI_ -D_SYRTHES_CFD_ -I/home/julien/Syrthes/syrthes4.3.0/src/syrthes-kernel/include -I/home/julien/Syrthes/syrthes4.3.0/src/syrthes-kernel/lib_material_syrthes -I/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/include -I/home/julien/Syrthes/syrthes4.3.0/src/syrthes-kernel/include utilitaire.c -o /home/julien/Syrthes/syrthes4.3.0/build//utilitaire.o
Makefile:35: recipe for target 'syrthescfd' failed
make: *** [syrthescfd] Error 2
function report
Before using SYRTHES, each user must source
the /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes.profile file before using the code.
The easiest way is to put the following lines in each of the users
'.profile' or '.bashrc' (depending on the shell)
syrthesprofile=/home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes.profile
#(adjust path to your system)
if [ -f $syrthesprofile ] ; then
. $syrthesprofile
fi
Warning : installation of some composants failed
Check log files for more information....
Julien
function report
. $syrthesprofile
fi
Julien
You should not have:
but (maybe):mpi USE=yes PATH=/usr/bin
As it seems Syrthes is installing its own MPI library, which may cause problems when coupling (as the coupling uses MPI, it should use the same library).mpi USE=yes PATH=/usr
I restart with the new setup.ini file
The installation time is only 10 min, the first time I install Syrthes was maybe 1 hour, is it normal?
I join the log files for mpi and others
Julien
Julien
- syrthescfd.log
- (68.73 KiB) Downloaded 652 times
- syrthesmed.log
- (9.11 KiB) Downloaded 685 times
- syrthesmpi.log
- (58.68 KiB) Downloaded 669 times
I try to rerun the coupled case CS and Syrthes (tuto 3disks2d).
This is the setup of my coupling_parameter.py file:
domains = [
'domain': 'fluid',
'n_procs_min': 1,
'n_procs_max': 1}
'domain': 'solid',
'n_procs_min': 1,
'n_procs_max': 1,
This the runcase file:
#!/bin/bash
# Run command:
The solid.syd file is joined.
I have the following error in the terminal:
Version: 4.0
Result directory:
/home/julien/3disks2D/RESU_COUPLING/20160706-0857
MPI home directory: /usr
Name = solid
Debug = False
Execution dir. = /home/julien/3disks2D/RESU_COUPLING/20160706-0857/solid
Data dir. = /home/julien/3disks2D/RESU_COUPLING/20160706-0857/solid
Source dir. = /home/julien/3disks2D/RESU_COUPLING/20160706-0857/solid/src
Post dir. = /home/julien/3disks2D/RESU_COUPLING/20160706-0857/solid/POST
Echo = True
Restart = False
Coupling = True
-> OK
with errorcode 1.
mpiexec.openmpi noticed that process rank 0 with PID 1828 on node julien-VirtualBox exited on signal 11 (Segmentation fault).
solver script exited with status 139.
Post-processing..
--> /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4ensight -m "/home/julien/3disks2D/MESH/3rond2d.syr" -r "/home/julien/3disks2D/RESU_COUPLING/20160706-0857/solid/resu1.res" -o "resu1"
--> /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4ensight -m "/home/julien/3disks2D/MESH/3rond2d.syr" -r "/home/julien/3disks2D/RESU_COUPLING/20160706-0857/solid/resu1.rdt" -o "resu1_rdt"
I am not sure that the coupling is done correctly. And maybe also a problem with MPI
Julien
domains = [
'domain': 'fluid',
'n_procs_min': 1,
'n_procs_max': 1}
'domain': 'solid',
'n_procs_min': 1,
'n_procs_max': 1,
#!/bin/bash
# Run command:
Version: 4.0
Result directory:
Name = solid
Debug = False
Echo = True
Restart = False
Coupling = True
-> OK
with errorcode 1.
Post-processing..
Julien
- solid.txt
- (3.28 KiB) Downloaded 725 times
This is the listing file
- listing.txt
- (28.7 KiB) Downloaded 756 times
