Page 5 of 11
Posted: Tue Jun 28, 2016 8:06 am
by jgd23
I run the file runcase in a terminal, I have the following error, again related with the xml support
Code_Saturne is running
Version: 4.0
Path: /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64
Result directory:
/home/julien/CASE1/RESU/20160628-0903
Preparing calculation data
Preprocessing calculation
Starting calculation
/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/libexec/code_saturne/cs_solver was built without XML support,
so parameter file "file" may not be loaded.
Pile d'appels :
1: 0x7fd57c9063a0 <cs_opts_define+0x2a0> (libsaturne.so.0)
2: 0x7fd57c87d5a8 <main+0x98> (libsaturne.so.0)
3: 0x7fd57c252ac0 <__libc_start_main+0xf0> (libc.so.6)
4: 0x4007f9 <_start+0x29> (cs_solver)
Fin de la pile
Saving calculation results
Error in calculation stage.
I have the same thing in executing in the gui.
Julien
Posted: Tue Jun 28, 2016 1:12 pm
We need to restart from the beginning. Could you post your setup and/or config.log files ?
Posted: Tue Jun 28, 2016 1:20 pm
by jgd23
I post the setup and config log files
Thank you again
Julien
Posted: Tue Jun 28, 2016 4:30 pm
You need to set "use" to yes instead of no in the setup file for libxml2.
Posted: Wed Jun 29, 2016 7:55 am
by jgd23
I have installed libxml2. The set up and config log are attached
No error during installation.
I have the same error with xml support during the mesh checking and the computation:
Version: 4.0
Result directory:
/home/julien/CASE1/RESU/20160629-0853
Pile d'appels :
1: 0x7f6b267d23a0 <cs_opts_define+0x2a0> (libsaturne.so.0)
2: 0x7f6b267495a8 <main+0x98> (libsaturne.so.0)
3: 0x7f6b2611eac0 <__libc_start_main+0xf0> (libc.so.6)
Fin de la pile
Julien
Posted: Wed Jun 29, 2016 2:58 pm
You used the wrong path for libxml2. Simply use /usr.
Posted: Thu Jun 30, 2016 4:19 pm
by jgd23
Code Saturne in stand alone mode and with salome are working now for serial and parallel calculation!
I try to install Syrthes now.
I use the setup.ini attached and I have a message in the terminal:
Before using SYRTHES, each user must source
the /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes.profile file before using the code.
The easiest way is to put the following lines in each of the users
'.profile' or '.bashrc' (depending on the shell)
syrthesprofile=/home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes.profile
#(adjust path to your system)
if [ -f $syrthesprofile ] ; then
. $syrthesprofile
fi
Warning : installation of some composants failed
Check log files for more information....
I attach also the log files. I don't know which one is the more important for debbuging...
Julien
Posted: Thu Jun 30, 2016 7:11 pm
I do not recommend installing MPI for Syrthes, but using the system one (the same as for Code_Saturne, probably under /usr, but might be different. Otherwise, coupling with Code_Saturne might not work. You can test it before reinstalling, just in case...
The rest seems OK, and the messages might be just warnings...
Posted: Fri Jul 01, 2016 1:50 pm
by jgd23
I try to make the tutorial Three-2D-disks. With Syrthes alone I have the same error as reported in the post (calculation satge bloqued at 14%):
http://code-saturne.org/forum/viewtopic ... isks#p8278
I don't know if a solution was find for this issue?
Julien
Posted: Fri Jul 01, 2016 1:58 pm
by jgd23
Here is a copy of my listing file editor:
Data file of SYRTHES : tmp.data
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
SSSSSS
SSSSSS
SSSSSSSS YY YY RRRRRR TTTTTTTT HH HH EEEEEE SSSSSS
SSSSS YY YY RR RR TT HH HH EE SSSSSSSSS
SSSSS YYYY RR RR TT HH HH EE SSSSS
SSSSS YY RRRRRR TT HHHHHHH EEEEE SSSSS
SSSSS YY RR RR TT HH HH EE SSSSS
SSSSSSSSS YY RR RR TT HH HH EE SSSSSSSS
SSSSSSS YY RR RR TT HH HH EEEEEE SSSSSSSS
SSSSS
SSSSSSS
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
VERSION 4.3
*** SYRTHES : SUMMARY OF MAIN OPTIONS
- no heat and moisture transfert model used
- no thermal radiation calculation
*** SYRTHES : FILE NAMES READING
- Conduction mesh : /home/julien/3disks2D/solid/3rond2d.syr
- Results files : resu1
*** CONDUCTION : SUMMARY OF THE CALCULATION OPTIONS
- 3D cartesian calculation
- time step on the solid : 10.000000
- number of time step asked : 100
- chronological output asked (steps) : 25
- no calculation of the min and max temperature field
- no calculation of temperature flux field
- maximum number of iterations in the temperature solver : 100
- precision required for the temperature solver : 1.000000e-06
CONDUCTION INITIALIZATIONS
*** SYRTHES MESH
| Volumic mesh | Boundary mesh |
| Dimension | 2 | 2 |
| Number of nodes | 1632 | unused |
| Number of elements | 2904 | 360 |
| Nb nodes per elt | 3 | 2 |
*** verif_maill : number of elements reoriented : 0
!!! ERROR During the reading of physical properties
No material properties for 2056 elements
--> verify the key-words CPHY_MAT_...
List of concerned references :
1
3
4
