I didn't include the patches, but I did use solid mesh in aster format and made some modifications in calc_ifs_dnl_ops.py.
Now, in my current test, the usvima isn't call in begin of the each time step. It's call only in the ALE initialization (listing file). Do you know fix it?
Flávio
Two-way coupling code_saturne / code_aster
Oliveira77
Re: Two-way coupling code_saturne / code_aster
- listing.txt
- (1.92 MiB) Downloaded 417 times
- calc_ifs_dnl_ops.py
- (25.2 KiB) Downloaded 446 times
you could modify phyvar, or simply call usvima from cs_user_extra_operations (called near the end of each time step). I'll check with colleagues if we should call usvima at each time step in future releases.
