Simulation of air flow in a room
Damien Charreron
Re: Simulation of air flow in a room
Post by Damien Charreron »
You can find my case folder attached.
Damien
etudetest-tar.gz
(3.41 MiB) Downloaded 313 times
Jacques Fontaine
Post by Jacques Fontaine »
I found the bug:
void cs_user_mesh_thinwall(cs_mesh_t  *mesh) {   return; /* REMOVE_LINE_FOR_USE_OF_SUBROUTINE */
You need to remove "return;" in order to use subroutines.
JF
Damien Charreron
Thank you! I works much better now!
Would it be too much to ask you the few lines of command in order to set it as input with velocity and a temperature? It seems that mine are wrong.
Have a good week end!
Damien
Jacques Fontaine
I posted an example with sliding walls. This is quite similar with a wall/inlet. You must select faces and then you must select a side of the face with its normal. (surfbo)
JF
