Using the subroutine
David Monfort
Re: Using the subroutine "CFILTER.F"
Another interesting feature -- if your case is not too big ! (ncells < 10000) -- would be to run valgrind on 1 time-step. You can tell the code where to find the valgrind executable (if present) in the same Advanced options button I wrote about in previous post. This will tell you whether you have some memory corruption in the code.
Nazir Al Sayed
Hello
I run my calculations on a single processor, and i reserve 12GB of the memory as follows: # PBS-l select = 1: ncpus = 1: mpiprocs = 1: mem = 12GB: Saturn = 1
Also the size of my mesh is (30,30,11), what bothered is that the "CFILTER" works well for the model Smagorinsky-dynamic !
Please find attached files: listing, erreur, error, sortie, and compil.log
Nazir Al Sayed
Nazir Al Sayed
- listing.txt
- (42.95 KiB) Downloaded 419 times
Nazir Al Sayed
Attached file:erreur
- erreur.txt
- (644 Bytes) Downloaded 414 times
Nazir Al Sayed
Attached file sortie
- sortie.log
- (9.96 KiB) Downloaded 424 times
David Monfort
Could you send me a "tar" of your setup (xml file from the graphical interface, all the Fortran sources, lance script) without the mesh of course ;-)
I assume I can launch a test-case on a simple channel flow with your model, can't I ?
I'll try to have look [disclaimer: when I have time :-(] and see if I can understand your problem.
David
David
David Monfort
And here are some comments, after a quick look at your listing file.
It seems you changed the default settings for LES simulations. The default are the following and are strongly advised, but perhaps did you change them on purpose ;)
- second-order in time for all variables - 10 sweeps on the RHS reconstruction for the pressure, 5 for the velocity
Also, be careful as it seems you are doing a restart simulation from a first simulation with different turbulent models. This isn't forbidden at all, but be aware that what you are doing could cause weird behavior.
Nazir Al Sayed
Thank you for your advice and your jokes ;) ...
David Monfort
Nothing bad intended here ;-) sorry about my "jokes"... The fact is LES simulations can be quite sensitive :)
