I can trace the crash being related to the fact that label Ga_HET_O202 is not defined in the XML file (Ga_HET_O201 is defined, but no Ga_HET_02<x> is found for x > 1.
In the GUI, if I do not start with the dp_FCP file, only one class of coal appears, but if I add another, the label is not added. In addition. If I rename your dp_fcp to dp_HCP, the GUI is consistent with your file (1 coal, 8 classes), but at least one label for class2 (Ga_HET_O202) does not appear.
This seems like a GUI bug leading to a reader crash, but I don't know much about the combustion modeling version, so I'll try to check with Alexandre tomorrow.
Coal combustion modelling issue.
David Monfort
Re: Coal combustion modelling issue.
Hi all,
If Alexandre is not around these days, could you open a new ticket in the bug-tracker so that we don't forget this issue?
Thanks in advance anyway.
David
David
