CS v2.1.0 and subroutines
Re: CS v2.1.0 and subroutines
Interesting to note that problems seem to be related to MPI wrappers. Things are better than they used to be a few years ago regarding alternative mpi wrappers, but when several MPI libraries are installed, it seems that the symbolic links can point to different versions (I had a problem with this when I tried to reproduce your bug).
You can tell the setup file to use MPICH2 with the following installation options:
-compc = usr/bin/gcc
-compF = usr/bin/gfortran
-mpiCompC = none
-mpi = /usr/lib/mpich2 yes no
but things might fail due to symbolic links mixing libraries, even though we try to be robust, so using the MPI wrappers should in theory help here (though they seem to be the cause of the user subroutine problems).
Did you check if you also have the user subroutine problems using the MPICH2 compiler wrapper (mpiCompC = mpicc.mpich2) ?
When using compiler wrappers, you may also want to tru using the wrapper for compc in addition to mpiCompC.
Alexandre Guilloux
Post by Alexandre Guilloux »
When I use this option in the setup file:
-mpiCompC = none
The installation tell me there is no repertory "/usr/lib/mpich2". Indeed, this repertory doesn't exist.
I am trying to use  the MPICH2 compiler wrapper (mpiCompC = mpicc.mpich2), I will let you know.
Thanks again for your help.
Alexandre
Where is MPICH2 installed ? On my Ubuntu 11.10 install, with both Open MPI and MPICH2 installed, I have both /usr/lib/openmpi and /usr/lib/mpich2.
Alexandre Guilloux
I  tried to use  the MPICH2 compiler wrapper (mpiCompC =
mpicc.mpich2). There is the same problem. The subroutines are compiled but they are not used during the calculation.
Regarding the repertory:
Command: which mpicc.mpich2     -->  Result : /usr/bin/mpicc.mpich2
Command: /usr/bin/mpicc  -->  Result : /usr/bin/mpicc
For the installation of openmpi, I have installed the package :
- mpi-default-bin
- mpi-default-dev
- openmpi-common
- openmpi-checkpoint
- openmpi-doc
- openmpi-bin
And for mpich2:
- mpich2
- libmpich2-dev
- libmpich2-1.2
I have the repertory /usr/lib/openmpi which have include and lib folder.
I don't have usr/lib/mpich2 repertory.
Alexandre
Alexandre Guilloux
[problem solved]
I have install the library mpich2 manually, directly with the file on the mpich2 web site.
And now i have a repertory /bin in my mpich2 installation repertory.
So I have specify this option for the code_saturne installation in the setup file.
compC     /usr/bin/gcc
compF     /usr/bin/gfortran
mpiCompC  none
mpi    /home/alexandreguilloux/library/mpich2-intall    yes  no
And now it's working.
Code_saturne compile and use subroutines. And the calculation doesn't bug.
Thanks again Yvan for your help.
