Indeed!
The "total pressure" is defined in Code_Saturne as being: Ptot = Pred + rho0*g*(z-z0) + P0, where Pred is the so-called reduced pressure (i.e. the resolved pressure). If you want the dynamic pressure, you'll need to add 0.5*rho*U**2. You can do that by adding the usvpst.f90 subroutine in which you can defined your own variables, on a given mesh (ipart = -1 for the volumic mesh).
David
ps: In the formula for the total pressure, I've intentionnally forgotten the reference of the reduced pressure Pred0.
Setting non standard boundary conditions in simple calculation
Stéphane Blanchet
Re: Setting non standard boundary conditions in simple calculation
Hi everybody,
I have the same issue as Thomas's. I started a simulation with a velocity inlet, and now, I want a pressure inlet. So I changed the usclim.f90 file, and now it seems Code_Saturne only takes into account the velocity inlet I set for the first time.
Here is my code:
I really don't know what I am doing wrong, so if you have any idea...
Stéphane
Here is my code:
iphas=1
call getfbr('inlet', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
iel = ifabor(ifac)
itypfb(ifac,iphas) = ientre
icodcl(ifac,ipr(iphas))=1.d0
rcdocl(ifac,ipr(iphas),1)=380.d0
icodcl(ifac,iu(iphas)) = 3.d0
icodcl(ifac,iv(iphas)) = 3.d0
icodcl(ifac,iw(iphas)) = 3.d0
enddo Best regards
Stéphane
David Monfort
For sanity check, Stephane's question has been answered in a different thread (see https://code-saturne.info/products/code-saturne/forums/general-usage/817624553 )
