problem k-omega sst
eliberge
Re: problem k-omega sst
Post by eliberge »
I thought that the problem was solved with the 2.2.1 version but it wasn't.
It works with the LES turbulence model but not with the k-omega SST model.
I have tried to compile with the option --enable-debug. In this case the computation doesn't fail but it is very slow. Without the debug option, the following error is obtained :
** WALL DISTANCE
Min distance = 0.64600E-04 Max distance = 0.66626E+00
(Distance calculation done in 2600 iterations)
Signal SIGFPE (exception en virgule flottante) intercepté !
Pile d'appels :
1: 0x2ad9819df9e0 <+0x329e0> (libc.so.6)
2: 0x2ad9802cb327 <+0x146327> (libsvml.so)
3: 0x5d3d0f <> (cs_solver)
4: 0x4a5491 <> (cs_solver)
5: 0x42778c <> (cs_solver)
6: 0x422eb1 <> (cs_solver)
7: 0x2ad9819cbbc6 <__libc_start_main+0xe6> (libc.so.6)
8: 0x4224b9 <> (cs_solver)
Fin de la pile
The 2.2.1 and 2.3.1 versions have been tested with the same result. This error appears only with the installation on the PBS cluster.
Erwan
Are you using the same compiler on the cluster ? It is possible that in optimized code, several code paths may be executed simultaneously, including code which "should not be executed" and may lead to division by zero for example (this has been seen mainly on Itanium, but may occur with other agressive optimizing compilers).
In the beginning of src/apps/cs_solver.c (near lines 30-40), you could try to replace:
#if defined(__linux__) || defined(__linux) || defined(linux)
#if    (!defined(__ia64__) && !defined(__blrts__) && !defined(__bg__)) \
    || defined(DEBUG)
#define _GNU_SOURCE
#endif
#endif
with
#if defined(DEBUG)
#define _GNU_SOURCE
#endif
#endif
Then rebuild/reinstall the code (you can also add cs_solver.c to your user subroutines, but you will need to remove the
  bindtextdomain(PACKAGE, LOCALDIR);
  textdomain(PACKAGE);
lines near the end of that file to compile correctly (you will loose the French translations in the C part of the code doing so, but this is probably not too important).
