Mapped inlet when there are another inlet faces
Tsubasa
Re: Mapped inlet when there are another inlet faces
Post by Tsubasa »
Hello I removed some part you pointed out.
Now message shows
So what do I have to do for this?
call getfbr('mapped_inlet_duct', nlfac, lstfac)
if (ntcabs == ntpabs+1) then
  allocate(lstcel(ncel))
  do iel = 1, ncel
    lstcel(iel) = iel
  enddo
  coord_shift(1,1) = -0.02
  coord_shift(2,1) = 0.d0
  coord_shift(3,1) = 0.d0
  inlet_l = boundary_conditions_map(mesh_location_cells, ncel,                &
                                    nlfac, lstcel, lstfac,                    &
                                    coord_shift, 0,                           &
                                    0.01d0)
  deallocate(lstcel)
endif
  call field_get_n_fields(n_fields)
  call field_get_key_id("velocity", keyvar)
  call field_get_key_id("scalar1", keysca)
  interpolate = 0
 do f_id = 0, n_fields-1
!    call field_get_key_int(f_id, keyvar, ivar)
!    call field_get_key_int(f_id, keysca, iscal)
    normalize = 0
    call boundary_conditions_mapped_set(f_id, inlet_l, MESH_LOCATION_CELLS, &
                                        normalize, interpolate,             &
                                        nlfac, lstfac, rvoid,               &
                                        nvar, rcodcl)
  enddo
Hamada
Do you have a more complete stack trace for this ?
Tsubasa
Post by Tsubasa »
Please find the following.
1: 0x7ff1ac7c566d <ple_locator_exchange_point_var+0x7d> (libple.so.2)
2: 0x7ff1ad7475e1 <cs_boundary_conditions_mapped_set+0x171> (libsaturne-6.0.so)
3: 0x7ff1ad748362 <cs_f_boundary_conditions_mapped_set+0x1d2> (libsaturne-6.0.so)
4: 0x55a375fa5563 <cs_f_user_boundary_conditions_+0x277> (cs_solver)
5: 0x7ff1ad71c406 <condli_ini_+0x9b> (libsaturne-6.0.so)
6: 0x7ff1ad6eea78 <caltri_+0xc73> (libsaturne-6.0.so)
7: 0x7ff1aee2b82f <cs_run+0x5ef> (libcs_solver-6.0.so)
8: 0x7ff1aee2b0f8 <main+0x178> (libcs_solver-6.0.so)
9: 0x7ff1ace8ec87 <__libc_start_main+0xe7> (libc.so.6)
10: 0x55a375fa4fba <_start+0x2a> (cs_solver)
run_solver.log
(16.56 KiB) Downloaded 1050 times
error.txt
(831 Bytes) Downloaded 952 times
Hamada
Could you print the name of the variable in the loop in cs_f_user_boundary_conditions just before the call to cs_boundary_conditions_mapped_set to check which variable is causing issues here ?
Also, did you try this with version 7.0 in case some bug may have been fixed since ?
Tsubasa
Post by Tsubasa »
Are these infomation enough for you?
subroutine cs_f_user_boundary_conditions &
 ( nvar   , nscal  ,                                              &
   icodcl , itrifb , itypfb , izfppp ,                            &
   dt     ,                                                       &
   rcodcl )
! Module files
use paramx
use numvar
use optcal
use cstphy
use cstnum
use entsor
use parall
use period
use ihmpre
use ppppar
use ppthch
use coincl
use cpincl
use ppincl
use ppcpfu
use atincl
use atsoil
use ctincl
use cs_fuel_incl
use mesh
use field
use turbomachinery
use iso_c_binding
use cs_c_bindings
implicit none
! Arguments
integer          nvar   , nscal
integer          icodcl(nfabor,nvar)
integer          itrifb(nfabor), itypfb(nfabor)
integer          izfppp(nfabor)
double precision dt(ncelet)
double precision rcodcl(nfabor,nvar,3)
! Local variables
!< [loc_var_dec]
integer          ifac, iel, ii, ivar, iscal, ilelt, nlfac
integer          keyvar, keysca
integer          n_fields, f_id, normalize, interpolate
double precision xdh, rhomoy
double precision fmprsc, uref2
integer, allocatable, dimension(:) :: lstfac, lstcel
double precision, dimension(:), pointer :: brom
double precision, dimension(:,:), pointer :: vel
double precision, dimension(3,1) :: coord_shift
double precision, dimension(1) :: rvoid
type(c_ptr), save :: inlet_l = c_null_ptr
!< [loc_var_dec]
! Initialization
!< [init]
allocate(lstfac(nfabor))  ! temporary array for boundary faces selection
! Map field arrays
call field_get_val_v(ivarfl(iu), vel)
call field_get_val_s(ibrom, brom)
fmprsc = 1.d0 ! mean prescribed velocity
!< [init]
! Assign a pseudo-periodic channel type inlet to a set of boundary faces,
! using boundary condition mapping.
! For each subset:
! - use selection criteria to filter boundary faces of a given subset
! - use boundary_conditions_map_set and boundary_conditions_mapped_set
!   to apply a profile from inside the domain to the inlet, renormalizing
!   for some variables.
! The impled feedback loop allows progressively reaching a state similar
! to that of a periodic channel at the inlet.
  do iel = 1, ncel
    lstcel(iel) = iel
  enddo
                                    coord_shift, 0,                           &
                                    0.01d0)
  deallocate(lstcel)
endif
  interpolate = 0
    normalize = 0
                                        nvar, rcodcl)
  enddo
! Formats
! End
deallocate(lstfac)  ! temporary array for boundary faces selection
return
end subroutine cs_f_user_boundary_conditions
cs_user_boundary_conditions-mapped_inlet.f90
(7.92 KiB) Downloaded 1011 times
Tsubasa
Sorry, I meant to add a "print" statement for get the field id after line 206, run the code, and post the ouptut (along with run_solver.log to identify the matching field).
Tsubasa
Post by Tsubasa »
I run the following code. Is it what you mean?
    normalize = 0
    print *, f_id
                                        nvar, rcodcl)
  enddo
Let me post some files.
run_solver.log
(16.52 KiB) Downloaded 1025 times
error.txt
(832 Bytes) Downloaded 977 times
(7.94 KiB) Downloaded 1037 times
Hamada
THe "print *" output probably appears in the terminal you used to run the code, or in the batch output file if you are on a batch system. Can you check this ? An alternative is to replace
print *,
with
write(nfecra, *)
-If I remember correctly.
Otherwise if you have a very small test case, you can post it here.
Tsubasa
Post by Tsubasa »
This is a small test.
You can download them.
Would you test them?
mapped_inlet.med
(620.28 KiB) Downloaded 1231 times
test_mapped_inlet.zip
(437.39 KiB) Downloaded 1234 times
Tsubasa
The crash was due to a missing update in the example.
In cs_user_boundary_conditions.f90, line 182, replace "ntpabs+1" with simpley "ntpabs".
