Windkessel outlet boundary condition
Saturne_User2021
Re: Windkessel outlet boundary condition
Post by Saturne_User2021 »
Hello Yvan
I am still making progress in the development of the BC. However, I figurd out that the flow given by the UDF makes no physical sense. The code (cs_user_BC.f90) is as follows :
s_tot = 0.d0
sumpre = 0.d0
call getfbr('outlet', nlelt, lstelt)
do ilelt = 1, nlelt
  ifac   = lstelt(ilelt)
  volden = bmasfl(ifac) / bpro_rho(ifac) * surfbn(ifac) ! flow = massflux/density*S
  sumpre = sumpre+volden
  s_tot  = s_tot+surfbn(ifac)
enddo
print *, 'flow out', sumpre
print *, 'flow out', s_tot
here, sumpre is expected to be volumetric flow rate at the outlet and s_tot, the total surface area. However, the flow rate I get is quite small (E-13 m3/s) and the surface area is larger than the expected value.
Is there a good way to find what I am doing wrong here?
Are you running in parallel or on a single processor ? You have no parallel sum, so in parallel, what you print is only the sum local to a given partition.
If the surface is too large, did you check the units for your mesh (min/max coords in the logs will help you check that).
Finally, fo volden, be careful that the mass flux stored in bmasfl is an extensive value (already multiplied by the face surface).
