Does subroutine overwrite correctly?
Tsubasa
Re: Does subroutine overwrite correctly?
Post by Tsubasa »
As I said last post, simulation never started when I use tetra mesh.
Yvan, do you think it is only due to mesh quality or something other parameters?
I understand hexa and tetra are better for simulation, but generally tetra also provides acceptable solution.
Actually, I have to run simulation by tetra mesh because of my own postprocessing.
Also as I said, simulation can be done if I set velocity value at inlet (it means non-pressure drive flow).
Therefore, we can run pressure drive flow even with tetra mesh.
Let me post error message and something.
error.zip
(12.85 KiB) Downloaded 256 times
Would you Yvan and someone give me tips?
Tsubasa
