Dear Yvan,
I confirm you that adding the zone as head losses in the gui doesn't solve the problem.
Following your recommendations I have tried with another user routine. Unfortunately I see no print with the cs_user_parameters-base.c routine when adding bft_printf("here") inside each void function.
I have installed code_saturne on ubuntu 16.04 LTS and the routine in C are still not executed by the solver.
The problem appears both in serial and parallel runs.
Is it possible that the problem comes from C libraries used during the installation stage ? When I tried the installation on ubuntu I faced many installation problem. Especially the mpi.h file was not find during the compilation. The solution was to install mpi-default-bin/mpi-default-dev and to modify the setup script : mpiCompC mpicc and mpiCompCxx mpicxx.
PF
Compilation problem using standard user routine
Re: Compilation problem using standard user routine
Problems can come from an incorrect build, but this seems improbable, especially using different systems. Could you post an updated simple case here so that I can check the issue ? Ideally, run only the "prepare execution" step (advanced run parameters in the v6.0 GUI) and post the contents of the RESU/<run_id> directory, removing cs_solver. This would allow me to check that the local script which is generated is also correct.
Since we have already observed issues on som Ubuntu systems, there might be a problem here, but I suspect a simpler issue here (the kind of issue that is hard to find at first but may seem obvious in retrospect).
Dear Yvan,
I have reinstalled everything (OS and code_saturne 6.0.4) and now it works (ubuntu 18.04, 16.04 and also Debian 10). The messages are well printed in the listing file. I probably did something wrong during the installation stage.
Nevertheless there is another problem with the routine user_head_losses.c. I have attached a simple test case :
whereas in the fortran routine the
PF
- Rectangular geometry with upward flow
- Two meshes connected
- One of the mesh (middle of the duct) is associated with a cell zone called "porous"
- Note that a head losses zone associated to "porous" is defined in the gui
statement.if (strcmp(zone->name, "porous") == 0)
seems to work.call getcel('porous', nlelt, lstelt)
PF
- testCase2.zip
- (7.55 MiB) Downloaded 467 times
Your 2 syntaxes are not equivalent. The C equivalent of getcell is cs_selector_get_cell_list (you can find examples).
Using zones is recommended when possible because it avoids an allocation/copy/free of the selection, and can be called in a single source code line, but you need to define zones first. The names match the names you assign to volume zones in the GUI or using the cs_user_zones function.
Thank Yvan,
it's working !
PF
it's working !
PF
