Thank you very much Yvan, the code is working well now.
I want to save the "spg" variable, that I calculate in the cs_user_initialization.f90, in the results file to use it for post processing.
How can I do that?
Right now the "spg" variable it is present in the results file but it only contains zero values, even though I set values of 5 for it in the cs_user_initialization.f90 file.
I have attached below the files that I used for calculate the "spg" variable and transferring it to the solver.
Ionut
access fluid properties, cs_wall_function.h
Re: access fluid properties, cs_wall_function.h
- cs_user_parameters.c
- (4.96 KiB) Downloaded 751 times
- cs_user_initialization.f90
- (7.2 KiB) Downloaded 747 times
- cs_user_initialization.c
- (3.77 KiB) Downloaded 735 times
You are not using spg consistently:
- in cs_user_intialization.f90, you are allocating "spg" instead of accessing it using field_get_val_s_by_name("spg", spg) so you need to fix that.
- also, you defined spg as a field on all cells, but are defining values as if it were a subset of boundary faces, so you need to fix this.
- In case the field is not already in the preprocessing output, in cs_user_initialization.c, or cs_user_parameters (in cs_user_parameters.c, just after cs_user_model) add:
cs_field_t *f = cs_field_by_name("spg");
cs_field_set_key_int(f, cs_field_key_id("post_vis"), 1);Yvan
