Thank you for your answer, what doy mean by globally conservative ? in all domains ?
I can't see how I can impose a new velocity, is it already defined in the code(somwhere else) or I should create a new one ?
If it's the case, can you help me with that ?
Thank you,
Overset/Chimera Method in saturne
Re: Overset/Chimera Method in saturne
Globally conservative means the total exchanged quantity is not lost when interpolating between domains (it may be rescaled for this), but on a given surface subset, you may not have condervation of that quantity.
You do not need to define an additional variable in any case, just transform the flow conditions on one side to boundary conditions on the other (check src/base/csc2cl.f90 to see how this works).
Thank you for your answer.
Sorry for the confusion I meant by a new velocity, the velocity of translation of the mesh (domain), can you help me with the way I can impose it ?
I have a second question, for the rotation (already exisitng in the code), can I make the movement periodic in time or in space (imposing a degree of rotation) ? If yes, how can I do that ?
As I started modifying the code, there are things that I didn't really understand, if you can help me with it please.
the function :
It seems to me that that the 4th column in the "matrix" is for translation, no ? is the "matrix" defined elsewhere ?
what's the difference between "matrix" and "m" used in "_apply_vector_rotation"
This function, is only used for updating the coordinates, although it can do a rotation also, so why the "_apply_vector_rotation" and "_apply_tensor_rotation" are the ones used.
If I want to use the "_apply_vector_transfo", how should the other functions be modified ?
Beause in a translation there won't be any invariant point, and in case it's a rotation/translation it the invariant point won't be the same.
I made a list of the other functions that should be modified, if you canfirm it, or add ones that I missed
I'm sorry if it's long, but your help is much appreciated
Mehdi
the function :
static inline void
_apply_vector_transfo(double matrix[3][4],
cs_real_t c[3])
int i, j;
double c_a[4] = {c[0], c[1], c[2], 1.}; /* homogeneous coords */
double c_b[3] = {0, 0, 0};
for (i = 0; i < 3; i++)
for (j = 0; j < 4; j++)
c_b += matrix[j]*c_a[j];
c = c_b;
- "cs_turbomachinery_rotate_fields"
- "cs_turbomachinery_rotation_matrix"
- "cs_turbomachinery_add_rotor"
- the update coordinates part of "_update_mesh"
- "_relative_velocity"
- "_update_geometry"
- rotation.c -> "cs_rotation_t"
Mehdi
I don't currently have access to my computer, so cannot check everything, but can confirm this:
- the last (4th) column of the homogeneous rotation matrix is a translation. So for a pure translation, use an identity matrix for the rotate part.
- you can the ignore the vector and tensor rotations.
Thank you Yvan for your answer.
I made a little modification to the file 'cs_turbomachinery.c', I deleted the call "if (tbm->n_rotors > 0)" and then imposed the transformation matrix (making it only a translation) using "cs_user_turbomachinery.c".
I got some errors which suggested to me to add and modify the mesh periodicity.
I still get an error :
So the problem looks to be in the mesh joining rather than in the _update_mesh of turbomachinery, isn't it ?
Can you help me with what I should modify ?
Enclosed, you'll find the files that I put in my SRC and the listing and error I get
Mehdi
So I modified the max_sub_face and made it to 10 000, 100 000, but I still get this error.Cannot achieve to reorient the current joined face with face 1857 (selected face).
Mehdi
- listing.txt
- (14.18 KiB) Downloaded 289 times
- cs_user_turbomachinery.c
- (5.16 KiB) Downloaded 284 times
- cs_user_mesh-periodicity.c
- (9.16 KiB) Downloaded 288 times
The best option to understand the joining error would be to apply the same transformation (translation) as a mesh preprocessing (cs_user_mesh_modify) step, and use standard (not turbomachinery, but preprocessing) joining, so as to visualize the mesh and joining problems.
