Yes...you can access with ntcabs ; Current absolute time step number. In case of restart, this is equal to ntpabs + number of new iterations.
How to access to the mass flow of a cross section?
Luciano Garelli
Re: How to access to the mass flow of a cross section?
Hi Code Saturne develop team:
In the script I access the mass flow rate of a certain layer of internal faces, and obtain the summation of the mass flows, then output the total mass flow to a file:
call field_get_key_int(ivarfl(ivar), kimasf, iflmas)
call field_get_val_s(iflmas, imasfl)
do ifac = 1, nfac
z_coord=cdgfac(3,ifac)
if(z_coord .gt. 0.00424 .and. z_coord .lt. 0.00426)then
totalmassflow = totalmassflow + imasfl(ifac)
endif
enddo
OPEN(2,FILE='output_massflow.txt',status='replace')
write(2,*)totalmassflow
close(2)
There is a problem, 8 processors are used in the simulation, every time only the mass flow information of a single processor is output to the file. What should I do if I need to calculate the mass flow of this cross section when the simulation is using 8 processors. Thanks for the time.
Regards!
Jundi
do ifac = 1, nfac
endif
enddo
close(2)
Regards!
Jundi
Luciano Garelli
If you have debug your script and it works in a serial run, the next step is to parallelize it. Each processor will have a set of cell, depending on the partition method used, wherewith each processor will compute a portion (local) of the total mass flow, then you have to do a parallel sum of this local values (parsom()). To do that you can check the following example scripts and documentation:
cs_user_extra_operations-global_efforts.f90
cs_user_extra_operations-parallel_operations.f90
https://www.code-saturne.org/doxygen/sr ... _8f90.html
Finally, if the processor rank=0 do the write operation
Luciano:
Thanks for the examples. It seems useful for me. I'll try if it works.
Regards!
Jundi
Regards!
Jundi
Luciano:
Should I obtain and output the total mass flow (of a cross section) like this:
do ifac = 1, nfac
endif
enddo
if (irangp.ge.0) then
call parsom(totalmassflow)
endif
close(2)
Regards!
Jundi
do ifac = 1, nfac
endif
enddo
endif
close(2)
Regards!
Jundi
Luciano Garelli
I think that yes, but you have to modify the write operation and initialize to zero totalmassflow variable. Try with this modifications.
totalmassflow = 0.0
do ifac = 1, nfac
endif
enddo
endif
if (irangp.le.0) then ! Serial run irangp=-1, parallel run irangp=0 -> Master write
write(2,*) totalmassflow
close(2)
endif
Luciano:
Thanks for the help! Yes I should initialize the total mass flow rate at the begin, and then calculate the summation. Many thanks!
Regards!
Jundi
Regards!
Jundi
