How to customize the nature of the material in Code Saturne?
Re: How to customize the nature of the material in Code Satu
Either one should work. Only the mesh numbering should be different.
xingjian
Post by xingjian »
Sorry, I do not quite understand what 'mesh numbering' means. Are they 'Symmetry 1' and 'Symmetry 2' which is periodic BC?
Thank you very much
Best Regards
XING Jian
Mesh numbering is an internal property, so you can ignore it.
You need both Symmetry1 and Symmetry2 in you selection criteria, which implies a logical "or":
"Symmetry1 or Symmetry2"
xingjian
Post by xingjian »
Excuse me for giving you so much trouble, thanks, two more questions, what is the unit for Exchange coefficient which is in the boundary conditions in the GUI? And what's the meaning of 'Prescribed flux' in the Thermal Type of Boundary conditions? If the flux is equal to 0, does it mean that there is no heat exchange?
Thank you very much
Best Regards
XING Jian
The units should be in international system units (with flux in W/m2 = h(delta T)).
And yes, 0 flux = adiabatic.
