Hi Luciano,
You are right! I have changed the output to every time step.
Now I can view them
However, I wonder will this changes the results?
thanks,
Kenneth
Post process CS result with ParaView
Re: Post process CS result with ParaView
Why would you expect visualization output to change the results ?
It will make the code run slower and output more data, but it should never "change the results" (this would be a bug).
Yes should be no different. There is no problem now after i just change the settings in "result" to output every time step, instead of add another writer that output for every time step.
Thanks much!
Kenneth
Thanks much!
Kenneth
