error while installing MED
sofiane73
Re: error while installing MED
Post by sofiane73 »
Hi
I have installed zlib1g-dev the i got another error while installing MED
I solved it with installing python-dev
no I have another problem with the installation of scotch
I have attached the log. I did install mpi but in vain
Sofiane
install_saturne.log
(294.01 KiB) Downloaded 920 times
Could you please provide the other details as per the forum's recommendations ?
You seem to be missing MPI development headers.
sofiane73
Post by sofiane73 »
sorry
I attached the config.log
config.log
(195.9 KiB) Downloaded 898 times
Scotch is optional, and sometimes a pain to install (especially when we try t automate that step), so if you have issues with it, you can opt not to use it in the setup configuration.
sofiane73
Post by sofiane73 »
Hi
I did. Hope it will not limit the capabilities of the code version i will use
I moved to parmetis and i have got an error during the installation
I attached the files
Sofiane
install_saturne.log
(150 KiB) Downloaded 936 times
config.log
(195.9 KiB) Downloaded 956 times
As I said in a previous message, you are missing mpi.h. You need to install MPI developement headers (openmpi-dev or mpich-dev or something similar) if you want to compile with MPI.
sofiane73
Post by sofiane73 »
I did
/usr/include/mpich/mpi.h
the installation script fails to locate it
how can i get around this problem?
Sofiane
Again, what do you have in the installer's "setup" file ?
sofiane73
Post by sofiane73 »
Hi
both mpiCompcxx and mpiCompc are set as auto
I have attached the setup
Sofiane
I believe you forgot the attachment.
