Please find attached the outputs of the commands.
Many thanks for your time.
Vilas
medCoupling for saturne-aster coupling
Re: medCoupling for saturne-aster coupling
- output1.txt
- (689 Bytes) Downloaded 928 times
- output2.txt
- (69.91 KiB) Downloaded 934 times
This is strange: your error message mentioned:
Also (probably an independent issue), I was able to get the coupling running (10 iterations) using Code_Saturne 4.0 or trunk with SALOME-MECA 1015.1, but not with SALOME-MECA 1015.2...
While your "nm /home/vilas/saturne/4.2.1/lib/salome/libSalomeIDLFSI.so.0" command does not seem to mention this symbol (but only _ZN19Engines_Component_i20configureSalome_fileESsSsP13Salome_file_i, which exists in the libSalomeContainer.so library).Error loading /home/vilas/saturne/4.2.1/lib/salome/libFSI_SATURNEExelib.so: /home/vilas/saturne/4.2.1/lib/salome/libFSI_SATURNEExelib.so: undefined symbol: _ZN19Engines_Component_i20configureSalome_fileENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEES5_P13Salome_file_i.
