Are there any news please?
Fatima
Coupling Neptune/syrthes
Re: Coupling Neptune/syrthes
Hello again,
I got some news, I now get this new error message but I still don't know how to get through it:
[chausson:10825] *** An error occurred in MPI_Allreduce
[chausson:10825] *** reported by process [47672487641089,47669842018304]
[chausson:10825] *** on communicator MPI_COMM_WORLD
[chausson:10825] *** MPI_ERR_COMM: invalid communicator
[chausson:10825] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[chausson:10825] *** and potentially your MPI job)
with errorcode 1.
[chausson:10823] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[chausson:10823] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
solver script exited with status 5.
Can anyone help please?
Fatima
with errorcode 1.
Fatima
Did you check the listing (fluid) and syrthes.log (solid) files ?
Yes, the second fluid listing gives this error :
SYRTHES coupling 0: initializing MPI communication ... SIGTERM signal (termination) received.
Syrthes can't read the second coupling I think but I can't figure out why?
Fatima
Fatima
Hey again,
I changed the names of the fluid cases and now syrthes can read the 2 surfaces. However, it stops after the 1st iteration and gives this error in syrthes.log file :
[chausson:27801] *** Process received signal ***
[chausson:27801] Signal: Segmentation fault (11)
[chausson:27801] Signal code: Address not mapped (1)
[chausson:27801] Failing at address: (nil)
[chausson:27801] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10330)[0x2b29e8ba0330]
[chausson:27801] [ 1] /lib/x86_64-linux-gnu/libc.so.6(fclose+0x4)[0x2b29e8e1b8d4]
[chausson:27801] [ 2] ./syrthes[0x40767f]
[chausson:27801] [ 3] ./syrthes[0x402cbf]
[chausson:27801] [ 4] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x2b29e8dcff45]
[chausson:27801] [ 5] ./syrthes[0x402ee5]
[chausson:27801] *** End of error message ***
and in the terminal I get this:
mpiexec noticed that process rank 0 with PID 29427 on node chausson exited on signal 11 (Segmentation fault).
Fatima
Fatima
There are recent threads on this forum in which I explain how to compile Syrthes in debug mode, so you can try that. It may provide a bit more info on where the issue is coming from, so if it is a known issue (for which patches should also be available on somewhat older discussion threads here), you may solve it. If it is an "unknown" Syrthes bug, someone would need to debug that...
