Radiation in SYRTHES 4.3
jgd23
Re: Radiation in SYRTHES 4.3
Post by jgd23 »
I follow your advice and it seems to work
julien@julien-VirtualBox:~/essais_syrthes/four_tuto/four_syrthes/PART$ syrthes4med30 -m mesh_conduction_ok.syr -r resu1_00006part00000.rdt -o chrono.med
SYRTHES4MED30
SYRTHES --> MED INTERFACE
Transform SYRTHES results files to MED format
Read Syrthes geometry (head)...
Dimension 3
Dimension of elements 3
Number of nodes 11485
Number of elements 37716
Number of elements of bound 19006
Number of nodes per element 4
Read Syrthes geometry (coordinates)...
--> End of Syrthes nodes coordinates read
Writing MED coordinates... ok
Read Syrthes geometry (elements)...
--> End of Syrthes connectivity read for elements
Writing MED connectivity for elements... ok
Read Syrthes geometry (elements of bound)...
--> End of Syrthes connectivity read for elements of bound
Writing MED connectivity for elements of bound... ok
Geometry conversion completed
Results conversion...
*** timestep=50, time=15000.000000, delta t=300.000000 ***
VAR=TEMPERATURE, type=3, nb=1918
MED write: timestep=50 time=15000.000000 field=TEMPERATURE 1918 values on nodes
*** timestep=100, time=30000.000000, delta t=300.000000 ***
MED write: timestep=100 time=30000.000000 field=TEMPERATURE 1918 values on nodes
*** timestep=150, time=45000.000000, delta t=300.000000 ***
VAR=julien@julien-VirtualBox:~/essais_syrthes/four_tuto/four_syrthes/PART$ syrthes4med30 -m mesh_conduction_ok.syr -r resu1_00006part00000.rdt -o chrono.med
SYRTHES4MED30
Dimension 3
MED write: timestep=150 time=45000.000000 field=TEMPERATURE 1918 values on nodes
*** timestep=200, time=60000.000000, delta t=300.000000 ***
MED write: timestep=200 time=60000.000000 field=TEMPERATURE 1918 values on nodes
Results conversion completed
SYRTHES4_TO_MED30
End of process
SYRTHES4_TO_MED30
End of process
A file chrono.med is created but when I try to open it with paravis it crashes.
Julien
jgd23
Post by jgd23 »
I use the global mesh in the command, not the partionned one
If the file crashes ParaVis, could you try converting to EnSight format instead ? PARAVIS can also read that format.
