For the Stator and Rotor to join correctly when rotating, you need the interface beween the two to be round, not square.
How to use the Turbomachinery module?
Re: How to use the Turbomachinery module?
hello,Yvan
thanks for your reply.i feel grateful to see you reply.but i still feel confused.
just as you said, when i use the geometry that i uploaded,how can I define the interface?or maybe how can i define the mesh?
sometimes I use the conplex geometry,such as the wind turbine with blades,how can I define the interface ? it is not round or square.
regards
binger
regards
binger
hello,YvanYvan Fournier wrote:Hello,
regards
binger
There is no tutorial for turbo-machinery yet, but you can check user meeting presentations for some descriptions, and there are also previous threads on this in this forum.
In any case, you need the rotor mesh to "slide" with a very small gap (as small as possible) relative to the stator mesh, so your mesh should be built with this in mind. The rest is just a matter of selecting surfaces and volumes.
