Hello there!
I'm having the same issue with ubuntu 14.04 code_saturne-4.0.4 and SALOME-MECA-2015.2.
I compiled code saturne following the automated script, specifying the fortran compiler as follows at the setup file:
compF /usr/bin/gfortran
I'm also linking the salome libraries before launching salome like this:
export PYTHONHOME=/vmSoftware/salome_meca/V2015_2/prerequisites/Python-273
source /vmSoftware/salome_meca/V2015_2/salome_prerequisites.sh
source /vmSoftware/salome_meca/V2015_2/salome_modules.sh
did you find any solution?
saturne asks for gfortran 1.4
Re: saturne asks for gfortran 1.4
Same question: do you have this issue when running under SALOME, or when running "standalone" (i.e. without sourcing the SALOME environment) ?
I was running code_aster in standalone mode, but I found a permanent solution adding this line to my ~/.bashrc file:
I hope it helps.
Thanks for your attention.
export LD_PRELOAD=$LD_PRELOAD:/usr/lib/x86_64-linux-gnu/libgfortran.so.3Thanks for your attention.
mboucheron
I had the same issue on Ubuntu 16.04 LTE, with Code_Saturne_4.0.7 and Salome_7.8.0, running from Salome (not standalone).
I fixed it by replacing
with
I kept the original adding "_old" at the end, and removed ".0.0" from the other to have the correct name...and it works ! Well at least it seems to work, I don't have the error message anymore. The library coming with Salome might be incomplete or something...
Hope this helps !
/home/maxime/salome/Salome-V7_8_0-public/prerequisites/debianForSalome/lib/libgfortran.so.3Code: Select all
/usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0Hope this helps !
MB
MB
Hi!
That problem is easy to repair.
use that command for find libgfrotran correct version.
locate libgfortran.so.3.0.0
example: usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
Create a link a that lib for you libgfortran problem. This directory was have in saturne error, (I to use module that saturne (CFDSTUDY) on salome_meca, is the same)
example: /home/tesis2/salome_meca/V2016/prerequisites/debianForSalome/lib/libgfortran.so.3
use that command to link new libgfortran
sudo ln -sf usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0 "/home/tesis2/salome_meca/V2016/prerequisites/debianForSalome/lib/libgfortran.so.3"
Ready.
sorry to my bad english.
Ready.
