how to setup periodic temperature for an LES of a cuboid
mkendrick
Re: how to setup periodic temperature for an LES of a cuboid
Post by mkendrick »
Using valgrind was alot easier than anticipated!
The ivar values are as follows:
 ivar for ustsnv
           2
 ivar for ustssc
           5
valgrind output file attached
valgrind_output.tar.gz
(150 KiB) Downloaded 371 times
To use Valgrind with Code_Saturne, you need to tell the code to use valgring using the xml file (in the GUI, go to advanced parameters for the code execution options), or the user Python script.
In your run, Valgrind ran on the Python iterpreter used by the main script, not on the cs_solver executable itself...
mkendrick
Post by mkendrick »
Ah, yes this ouput looks more like it.
Attached.
valgring_output.tar.gz
(30 KiB) Downloaded 361 times
You have a memory overwrite in cs_user_boundary_conditions.f90. Checking your code, iscal is not initialized, so that is probably the cause of the error.
This may cause errors downstream, so you should fix this first, and check your run again (using Valgrind will help check everything is fixed, and if not, tell you where to look).
mkendrick
Post by mkendrick »
I think I've traced the problem to
kimasf
This value is used in the function below
field_get_key_int(ivarfl(iu),kimasf,iflmas)
If I write the output of kimasf I get
kimasf = 0
which I'm assuming is incorrect.
How do I initialize the 'kimasf'? or for my version (3.0.5) is there an easier way to find the mass flux?
Cheers,
Martyn
P.S. the two write errors were solved by replacing
ivar=isca(iscal)
with
ivar=isca(1)
and the other which was in subroutine ustsnv was solved by copying the arguments and initializations from cs_user_source_terms.f90 found in the REFERENCE folder.
