Can you post the whole code instead of just small pieces of it ?
[SOLVED] Problème calcul with cs_user_extra_operation
pleblanc86
Re: Problème calcul with cs_user_extra_operation
Please find attached the cs_user_extra_operations.f90 for a simple cases without computation of criteria.
We modified the code and program a ionic conduction module (Electrical Double Layer Effect), the scalar ipproc(iqelec) is calculated in this module and represent the space charge density at the interface solid/liquid.
icell3 is a color of only one cell close to interface (in medium liquid).
So my question is -> why when I am working with only one procs, I obtain 1.d0 in residu.dat file and 0.d0 with multi procs run ?
Thank you for your help
Paul
Paul
- cs_user_extra_operations.f90
- Cas test simple
- (6.38 KiB) Downloaded 734 times
Why did you remove the call to parsom ? In parallel, you need to call
parsom(residu(ntcabs))
After the loop on selected cells, and before writing the output.
pleblanc86
Thank you very much, does it works now.
I placed the line
where you suggested
Thank you again
Ragards
Paul
I placed the line
Thank you again
Ragards
Paul
