Second order time scheme
Jacques Fontaine
Re: Second order time scheme
Post by Jacques Fontaine »
The error appears only when you activate ischtp = 2 ?
fomeh
Post by fomeh »
Exactly and then whn I change it to =1, It works.
Jacques Fontaine
You can not use ischtp = 2 with all physical models (eg. RANS models - except Rij-e). In case of use ischtp =2 with incompatible options the error messages should be proper.
You could post your setup. I will check.
fomeh
Post by fomeh »
Ok, yes I've used the standard k-epsilon, so no need to verify the setup.
Thanks again Jacques
fomeh
Post by fomeh »
I've just tested Rij-e with the second order time scheme but it did not work. Are you sure about it?
my xml file and user paratmeters file are attached to this post.
Thank you
userparams.f90
(105 KiB) Downloaded 611 times
testparam.xml
(10.38 KiB) Downloaded 606 times
Jacques Fontaine
You can not use ischtp = 2 with steady flow algorithm ! You should use unsteady flow option with SIMPLEC algorithm.
fomeh
Post by fomeh »
Yes I am sorry. It works with Rij-epsilon.
Thank you very much Jacques.
