Re: Computation of a Simplified Centrifugal Blood Pump
Posted: Sat Dec 14, 2013 3:20 pm
Just a minor (but important) precision if you are new to the code:
When I talked about adjusting the time step, I meant the time step value, that is dt, and not the number (nt max). The value must be chosen for a reasonable CFL range, and the CFL (ou Courant number) will appear in your listing file (and also in the visualizable postprocessing output). Once the time step value is chose, you then need to run sufficient time steps for a "converged" solution. Checking probes is useful at that point, and a good rule of thumb is to run enough time steps that the mean flow has been convected twice through the domain.
Regarding mesh joining in the same domain, with version 3.2.1, could you post the detailed error log ? This will help me know if it is an error or just a warning. Also, an image of a part of your mesh (zoomed in near the rotor/stator junction) may help us judge "quality" and provide furtger recommendations.
