start calculation -> nothing happens
ggosse
Post by ggosse »
I'm a new user with salome and code_saturne.
Under windows 7, i managed the following steps:
- create a cylinder in salome
- create a mesh with groups inlet,wall, outler in salome
- export to .unv
- create a directory structure CASE in code saturne
- check mess ( seems ok , see below )
- configure physical properties, etc
Finally
When i open "prepare batch calculation", the runcase.bat script is found.When i launch "start calculation" a blank log window appears with just "number of lines" and "save as" enabled, and nothing more ...
If i try to shut the window, i get the message "The process is not running".
Any suggestion ?
Gregory
(check mesh finishes with this:
Checking the mesh structure coherency:
Checking the face -> cells connectivity coherency
Coherency criteria definition
Coherency verification on coordinates
End of coherency check of the mesh structure.
Destroying structures and ending computation
projet1.zip
(1.3 MiB) Downloaded 314 times
ggosse
Re: start calculation -> nothing happens
Post by ggosse »
I found the following post which seems to deal with the same issue :
http://code-saturne.org/forum/viewtopic ... tion#p9499
For me too, the double click of runcase.bat in windows explorer produces a folder with results in the 'RESU' folder.
Gregory
ggosse
Post by ggosse »
I attach the result folder.
I have then installed a standalone PARAVIEW for visualization ( the PARAVIEW installed with CODE SATURNE doesn't seem to work )
I can visualize the RESULT.case with PARAVIEW but i wonder if anything 'fluid' has been computed ??
20151214-1320.zip
(442.29 KiB) Downloaded 315 times
So far, you seem to have run only a "mesh quality criteria" type run. This is the recommended pratice to check your mesh quality, and see in which zones quality is good an which areas it is not so good (which can be very useful to interpret future results).
You now need to switch to a standard run (in the GUI, calculation type/prepare batch calculation/run type).
ggosse
Post by ggosse »
Thanks Yvan
I have performed a standard run now. ( attached folder )
In PARAVIEW the pressure, velocity ... are selectable.
If I choose velocity a color scale is displayed and take into account the inlet velocity I set in CODE SATURNE.
But the colors are not displayed in the figure. I just can see the shape of my cylinder even after having selected 'velocity' and 'apply'.
I will open a new topic for this.
Gregory
20151215-1056.zip
(891.16 KiB) Downloaded 294 times
Martin FERRAND
Post by Martin FERRAND »
In paraView, to visualise the fluid volume only (and not the boundary mesh) you should use filter->alphabetical->extract block
Then you can select the fluid domain only et click on apply.
You will be allowed to visualise pressure, velocity, etc
Martin
ggosse
Post by ggosse »
Thanks. The fluid visualization is ok with this filter.
File>Open result.case
Apply
Filter>Alphabetical>Extract Block
Check "Fluid domain"
Choose data in the scrolling menu in the "Active variable controls" toolbar
Gregory
ggosse
Post by ggosse »
( here is the result with a truncated cone )
Gregory
Martin FERRAND
When using a tetra mesh, we advice to activate "least square with extended neighbourhood" gradient calculation method in the GUI (or set: imrgra=2 in cs_user_parameters.f90).
Martin
ggosse
Post by ggosse »
Thanks Martin
Actually the result is more homogeneous with the least square with extended neighbourhood method.
Gregory
