Hello ,
I am looking to simulate a solid partially blocking a flow in a pipe and I was wondering what is the best way to do this.
I have created the solid's bounding surfaces group in the geometry and I defined them as WALL boundary condition. But the simulation results doesn't show the results or any effect showing the solid in the domain.
I was reading the tutorials and I saw the 3 discs example, I am wondering if I need SYRTHES for this? I am not simulating any conduction in the solid. I just want to simulate this volume inside the domain as walls.
Solid/boundary walls inside fluid domain
Re: Solid/boundary walls inside fluid domain
The "thin wall" fucntionnality of Code_Saturne is probably a better option.
Check the cs_user_mesh_thinwall() function in the cs_user_mesh.c user file
(this is where you can tell the code that faces of the group you defined should be boundary, not interior faces).
mhassab
The thin wall function in my cs_user mesh is as follows
* Insert thin wall into a mesh.
void
cs_user_mesh_thinwall(cs_mesh_t *mesh)
/* Example: thin wall along a plane */
if (false) {
cs_lnum_t n_selected_faces = 0;
cs_lnum_t *selected_faces = NULL;
cs_real_t *i_face_cog = NULL, *i_face_normal = NULL;
/* example of multi-line character string */
const char criteria[] = "plane[0, -1, 0, 0.5, epsilon = 0.0001]"
" or plane[-1, 0, 0, 0.5, epsilon = 0.0001]";
cs_mesh_init_group_classes(mesh);
cs_mesh_quantities_i_faces(mesh, &i_face_cog, &i_face_normal);
cs_glob_mesh->select_i_faces = fvm_selector_create(mesh->dim,
mesh->n_i_faces,
mesh->class_defs,
mesh->i_face_family,
1,
i_face_cog,
i_face_normal);
BFT_MALLOC(selected_faces, mesh->n_i_faces, cs_lnum_t);
cs_selector_get_i_face_list(criteria,
&n_selected_faces,
selected_faces);
cs_create_thinwall(mesh,
selected_faces,
n_selected_faces);
BFT_FREE(i_face_cog);
BFT_FREE(i_face_normal);
mesh->class_defs = fvm_group_class_set_destroy(mesh->class_defs);
mesh->select_i_faces = fvm_selector_destroy(mesh->select_i_faces);
So I removed the ''void'' and the if changed to be ''true''.
But I had no idea what is n_selected_faces or *selected_faces or *i_face_cog or *i_face_normal , even after checking documentation and Doxgyn.
It seems that along a plane those parameters above are to change, so I changed it to the follows, not sure if I see much difference in the answer.
Does this code pull the selected faces from the list in the GUI ? could you please clarify. If I have a faces group called X inside the volume, what should I do to make it a thin wall ?
if (true) {
cs_lnum_t n_selected_faces = 1;
cs_lnum_t *selected_faces = 1;
cs_real_t *i_face_cog = 1, *i_face_normal = 1;
mesh->n_i_faces,
mesh->class_defs,
1,
i_face_cog,
i_face_normal);
&n_selected_faces,
selected_faces);
selected_faces,
n_selected_faces);
void
if (false) {
mesh->n_i_faces,
mesh->class_defs,
1,
i_face_cog,
i_face_normal);
&n_selected_faces,
selected_faces);
selected_faces,
n_selected_faces);
if (true) {
mesh->n_i_faces,
mesh->class_defs,
1,
i_face_cog,
i_face_normal);
&n_selected_faces,
selected_faces);
selected_faces,
n_selected_faces);
If you have a faces group names "X" inside the volume, you should simply set the criterria in the example to "x":
replace:
with:
const char criteria[] = "X";
This should be enough.
replace:
with:
