Compiling CodeSaturne for co-processing (ParaView, Catalyst)
Hello.
I want to enable co-processing when calculating in Code_Saturne 4.0.2. I've read corresponding User's guide sections and configure's --help, but I haven't found a particular solution. Configure option --with-catalyst=/Path/To/ParaView4.3.1 doesn't work. How should I compile Code_Saturne to enable co-processing with live visualisation in ParaView?
Thanks.
Thanks.
Re: Compiling CodeSaturne for co-processing (ParaView, Catal
What error do you obtain ?
Did you also read the installation manual ? Paraview needs to be compiled with specific options enabled, and those are listed in that manual (you might also need to source some LD_LIBRARY_PATH and PYTHONPATH values).
Saturne's configure (version 4.0.2) says that Catalyst files not found in specified location. This is from Saturne's installation manual (part 4.3.6):
Simple method "--with-package=/Path/To/Package/Install/Prefix" worked OK on other packages (med, scotch, cgns libraries e.t.c.), but these packages (libraries) was compiled from sources (directory structure is like /Progs/Package/build, /Progs/Package/source; Saturne's configure is targeted to "build" dir). ParaView 4.3.1 installed in binary form (just official binary archive).
I use standard ParaView build. Is it needed to compile some additional libraries or to recompile ParaView? Sorry, I don't know much about Saturne compilation with Paraview's Catalyst.For use with Code Saturne, the recommended solution is to build or use a standard ParaView build for interactive visualization
2 lines just after one one you cite (in 4.3.6), you have an important addition, explaining that you need a second paraview build, for postprocessing.
You can also use a single build, but in this case, you will have graphical windows open during computation, and the code will only run using Catalyst output when connected to a graphical display (OK and possibly preferable for testing on a workstation, less OK for running on a cluster).
So I recommend following the recommendations in the rest of the paragraph in the installation guide.
It contains all the important info, except possibly required environment variables (for execution, not required at installation), which seem to be sometimes necessary, sometimes not (probably related to linker caching):
But first, let's see if you can compile with the recommended ParaView build.
You can place those definitions in your .profile or .bashrc file, but I prefer to place them in a specific file whose path is provided to Code_Saturne in the "rcfile" section of the code_saturne.cfg post-install file. I'd like to make this more automatic in the future, but since the paths depend not only on the ParaView prefix but also on its version, making it robust is not trivial...export PYTHONPATH=$PARAVIEW_PREFIX/site-packages/vtk:$PYTHONPATH
export PYTHONPATH=$PARAVIEW_PREFIX/lib/paraview-4.3/site-packages/paraview:$PYTHONPATH
export PYTHONPATH=$PARAVIEW_PREFIX/paraview-4.3/site-packages:$PYTHONPATH
export LD_LIBRARY_PATH=$PARAVIEW_PREFIX/lib/paraview-4.3:$LD_LIBRARY_PATH
Hello. Thanks for you response.
Sorry, I misunderstood the Guide... If I get you right, there are two ways:
1. Use only screen rendering. It's OK on our cluster if it can work with VNC remote connection.
2. Use offscreen rendering with OSMesa.
Is it possible to use the first way with VNC? If yes, what should I do? What prerequisties to compile and what additional Saturne's configure options to use?
I'm now trying to understand what to do with cmake options from Installation guide
for the second method (offscreen rendering).
I don't think using VNC will be a viable option, except for testing on a single node, because if the code is run in batch mode, the execution environment will probably not have an X11 "display". Add to that the the graphic cards are probably different on the front-end node and compute nodes...
There is a recent post on the ParaView web site explaining exactly how this can be worked around http://www.kitware.com/source/home/post/162, but it's not exactly simple (the advantage over using Off-Screen Mesa is probably getting better performance, as the GPU drivers are used in their case, but the setup is much more complex).
So I recommend using the Off-Screen Mesa option, although for testing on a workstation and familiarizing yourself with co-processing, using a single "standard+MPI+enable_coprocessing" ParaView install may be a good start.
Yes, I forgot about this... OK, assuming "OSMesa" method. I've read some manuals and downloaded Mesa and ParaView sources. Now trying to compile (at the moment mesa's configure cannot find dri3proto on my laptop with CentOS 6.5 so I'm serching the solution).
If you have any luck, OSMesa should be available as a package under CentOS (it is at least for Debian, Ubuntu, and Arch Linux).
If you do not have administrator privileges, of course, you need to install it in a user account.
This is a a pain, as you've probably already guessed.
For my builds (where I have a user or project account, but no administrative privileges), assuming an ARCH environment variable defining an architecture subdirectory for multiple builds (which you can set for example to "CentOs", `uname`, or remove), and a PREFIX install subdirectory (in my case the project account path), I last used the following command for Mesa-10.4:
I am not sure GLU is important or not, so I also build it, to be safe...
For some older environments, even building OSMesa is a pain, due to missing environments. On Debian 6 systems, I also need to download and build util-macros, makedepend, and glproto (hopefully you won't need to bother with this).
Hope this helps.
export PATH=/usr/bin:/bin:/usr/local/bin # set minimal PATH
cd Mesa-10.4.0/
./configure --prefix=$PREFIX/opt/Mesa-10.4/$ARCH --with-osmesa-bits=32 --disable-dri --enable-dri=no --disable-egl --with-gallium-drivers=no --enable-osmesa
make -j 4
make install
make clean
cd glu-9.0.0/
export PKG_CONFIG_PATH=$PREFIX/opt/Mesa-10.0/arch/calibre7/lib/pkgconfig
./configure --prefix=$PREFIX/opt/Mesa-10.0/arch/calibre7 --enable-osmesa --enable-shared --disable-static CFLAGS=-std=c99
make && make install && make distclean
export PATH=$PREFIX/usr/arch/$ARCH/bin:$PATH
export PKG_CONFIG_PATH=$PREFIX/usr/arch/$ARCH/share/pkgconfig:$PREFIX/usr/arch/$ARCH/lib/pkgconfig:$PKG_CONFIG_PATH
cd util-macros-1.17_build/$ARCH
../../util-macros-1.17/configure --prefix=$PREFIX/usr/arch/$ARCH
make clean && make && make install && make clean
cd ../..
cd makedepend-1.0.4_build/$ARCH
../../makedepend-1.0.4/configure --prefix=$PREFIX/usr/arch/$ARCH
cd ../..
cd glproto_1.4_build/$ARCH
../../glproto-1.4.16/configure --prefix=$PREFIX/usr/arch/$ARCH
cd ../..
I've built Mesa-9.2.0 successfully with options provided in ParaView instruction:
http://www.paraview.org/Wiki/ParaView_And_Mesa_3D
(I think modern version of Mesa will also compile on my laptop)
I don't know if it works correctly because I cannot compile ParaView-4.3.1...
Now I'm trying to compile ParaView but without success. I follow instructions in official manual:
http://www.paraview.org/Wiki/ParaView:B ... _libraries
But when running configure in ccmake for the first time I receive an error because default Qt version in CentOS 6.5 is 4.6.2 but current ParaView-4.3.1 requires Qt-4.7 minimum (4.8 recommended). Qt developement package requires several dependencies, and with only Qt-4.8.x libraries (without developement files) ParaView still doesn't see this Qt version (it's obvious that , at least, Qt headers are required for compilation). The problem is that our cluster is not connected to the internet for security reasons so it's useless to install Qt-4.8 developement package on a laptop while testing installation process (I can easily connect notebook to the internet). I cannot find a complete Qt-4.8.x offline installation so I decided for now to use the old version of ParaView for co-processing (possibly ParaView-3.12).
You don't need Qt for the OSMesa build of ParaView, so you should be OK (as long as you use a separate, "standard" build on a workstation with the co-processing script generator plugin).
In the section relative to ParaView in the Code_Saturne install doc, the option used to disable Qt is:
If you did not add this (and -DVTK_USE_X=OFF) the first time you ran ccmake, you won't be able to change that value, due to CMake's caching (or in any case, if commands are available to do this, I'm not an advanced enough user of CMake for this). So the solution is to completely remove your build directory, recreate it, and restart a clean build in that new, empty directory.
Good luck,
(though the other options are important too).-DPARAVIEW_BUILD_QT_GUI=OFF
Good luck,
