Hello developer and user,
I am using code_saturne 3.0.*. I am trouble with auto saving interval of chechpoint. It waste a lot of my computing sources. Can it be modified by change the value like:
if ture:
domain_auto_restart(domain, 200)
return
in 'cs_user_scripts.py'.
Waiting for your reply.
Thanks in advance,
Yu.
How to control the interval of checkpoint
Re: How to control the interval of checkpoint
The auto_restart example is for a different use (updating the number of time steps for a restarted calculation, without otherwise changing the calculation options).
Did you check the GUI start/restart section ?
I am using the subroutines to set up the case. Can you please give me some ideal about modify the saving interval of checkpoint? I am running the case on the supercomputers, the job would killed if the required time is up.
For example, I had a case had been forced to stop at time step 3228, but the checkpoint started from 2400. There was 800 calculation lost. A small saving interval would help to close this big gap.
Thanks very much.
Yu.
Thanks very much.
Yu.
Yvan Fournier wrote:Hello,
If you are using user subroutines, you will find all relevant information in the user manual (ntsuit and control_file).
I check the manual but I did not find any example. Can the control file just contain two lines like:
max_time_step <14000>
checkpoint_time_step <400>
I attached the file as well. Can you please have a look?
Yu.
Yu.
- control_file.log
- (49 Bytes) Downloaded 704 times
You syntax seems correct.
Just test it.
Just test it.
I found a interesting thing that the 'control_file' will be deleted after the simulation running.
I put is in the excecutive directory like '/RESU/20141209-1344'. When I had a look at this directory again, the 'control_file' dissapeared.
Do you have any idea about this? I am using code_saturne 3.0.3.
Yu.
Yu.
Just test it.
I putted the 'control_file' in the directory <Study_Case>/RESU/********-****, which should be my executive directory.
It seems the 'control_file' did not work.
The attached is the 'control_file' and 'cs_user_scripts.py'. Can you please have a look?
I can't thank you enough for your help.
Yu
Yu
Just test it.
- cs_user_scripts.py
- (12.82 KiB) Downloaded 670 times
- control_file.log
- (48 Bytes) Downloaded 689 times
Sorry, I did not notice the < and > characters in the control file.
You must remove those (in most Linux manuals, you will find < > to denote required parameters, [ ] to denote optional parameters; we use this same convention).
So you should simply use:
Regards,max_time_step 14000
checkpoint_time_step 400
