Wall shear stress calculation
Re: Wall shear stress calculation
Adding the following file to your SRC directory should provide a fix, while waiting for 3.0.4:
- cs_gui_output.c
- (60.36 KiB) Downloaded 2806 times
Loïc A.
Thank you for your quick response! It works.
Loïc.
Loïc.
MartianDuan
I am trying to use code_saturne 3.0.1/3.0.3 to do parallel the large eddy simulation with WALE SGS model. I need to calculate the wall shear stress as well. My cases were set up by sub-routines. From my research I need to modify a branch sub-routine to get the averaged wall shear stress. My main problem is how to allocated the user-defined array, which need to be called in 'clptur.f90'. According to the reply in this topic, that I can define it in the 'cs_parameters.f90'. So What I did was adding the following line in the subroutine 'usipph'
!user defined array to store wall shear stress usertau, and friction velocity userutau
double precision, allocatable, dimension(:) :: usertau, userutau
integer nfac
allocate(usertau(nfac))
allocate(userutau(nfac))
The problem is these user defined arraies did not transfer to the 'clptur.f90' and 'cs_user_postprocess_var.f90'. The compile log had been attached.
I also tried Brian Angel's suggestion. Defined the user-defined arraies in the 'user_modules.f90' and call it in 'clptur.f90' and 'cs_user_postprocess_var.f90'. It did solve the compilation problem. But it brought the fatal error 'SIGSEGV signal (forbidden memory area access) intercepted!' during the calculation. The listing file and 'cs_user_modules.f90' is attached as well.
Meanwhile, I try to calculate mean wall shear stress instead of instantaneous one. So I added following lines in 'clptur.f90'. I am not sure is it ok or not.
if(iturb.eq.42.and.idries.eq.0) then
tau = romc*uet**2
tau0 = 0.0d0
uet0 = 0.0d0
if (ntcabs .gt. 3600) then
tau0 = tau0+tau
uet0 = uet0+uet
endif
usertau(ifac) = tau0
userutau(ifac) = uet0
endif
I spend a lot of time on this problem. Hope you can give me some suggestions. If you had some example subroutines, can you please shear it with me?
Thanks in advance,
Yu.
integer nfac
tau = romc*uet**2
tau0 = 0.0d0
uet0 = 0.0d0
tau0 = tau0+tau
uet0 = uet0+uet
endif
endif
Thanks in advance,
Yu.
Yvan Fournier wrote:Hello,
I just checked, and this indeed seems to be a bug (it should work in 3.x). I'll try to fix it for 3.0.4, and in the meantime, send you a temporary fix by tomorrow.
- listing.log
- (42.02 KiB) Downloaded 2785 times
- cs_user_modules.f90
- (2.66 KiB) Downloaded 2789 times
- compile.log
- (16.45 KiB) Downloaded 2782 times
There were some fixes since 3.0.3, so I really recommend upgrading to patch release 3.0.5 (3.0.6 should be released with 2 or 3 weeks).
Did you call the "init_user_module" somewhere after reading the mesh but before the time loop (for example, in cs_user_initialization.f90/usiniv) ? If you did not, it probably explains the SIGSEGV.
MartianDuan
It doest solved the problem.
But how to calculate the averaged wall-shear-stress? What I had now is the instantaneous wall-shear stress.
I did added the sum function in the 'clptur.f90', but it dose not work. The lines were like:
tau = romc*uet**2
tau0 = 0.0d0
uet0 = 0.0d0
tau0 = tau0+tau
uet0 = uet0+uet
endif
endif
Thanks in advance,
Yu.
tau = romc*uet**2
tau0 = 0.0d0
uet0 = 0.0d0
tau0 = tau0+tau
uet0 = uet0+uet
endif
endif
Thanks in advance,
Yu.
Could you please follow the forum usage recommendations and post the complete user files ? I suspect you forget to add a "save" attribute, but can't check with just a snippet.
MartianDuan
Please see my attached 'clptur.f90'. What I added is from line 705 to line 717.
What I did in the 'cs_user_postprocess_var.f90' is just write the wall shear stress and friction velocity in to the us_results.
Thanks in advance,
Yu.
Thanks in advance,
Yu.
- cs_user_postprocess_var.f90
- (21.31 KiB) Downloaded 2799 times
- clptur.f90
- (76.48 KiB) Downloaded 2798 times
In your code:
you are resetting tau0 at each time step, even when you are trying to accumulate things.
You need to accumulate in an array reserved for this in your user modules, then divide by the number of time steps (weighted if they are not constant) ipon usage.
In versions 3.3 and above, new functions have been added to easily handle time averages, provided the variable you want to average is defined (+ created) as a field object. In version 3.0, you need to do this yourself.
In your code:
tau = romc*uet**2
tau0 = 0.0d0
uet0 = 0.0d0
tau0 = tau0+tau
uet0 = uet0+uet
endif
endif
MartianDuan
Thanks very much. The problem solved now. Although my solution is a little bit different from your suggestion. I initialized the user defined array with value zero in the 'cs_use_initialization.f90'. And the accumulation can be defined in 'clptur.f90'.
Best wishes,
Yu.
Best wishes,
Yu.
In your code:you are resetting tau0 at each time step, even when you are trying to accumulate things.Code: Select all
f(iturb.eq.42.and.idries.eq.0) then tau = romc*uet**2 tau0 = 0.0d0 uet0 = 0.0d0 if (ntcabs .gt. 3600) then tau0 = tau0+tau uet0 = uet0+uet endif usertau(ifac) = tau0 userutau(ifac) = uet0 endif
MartianDuan
Sorry for interrupting again.
Now I came across a problem on reusing the result of accumulation calculated previously. Can we save the results of user defined array into the 'checkpiont'? Or, do we had any other solution for this problem?
Thanks in advance,
Yu.
Thanks in advance,
Yu.
