Hi there
I'm new to CS, trying to simulate flow in a catalytic converter like the one attached:
Meshing: Salome 2013.1
Solver: Saturne GUI 3.0.0
Post: ParaView in Salome
When analyzing a single domain (the inlet or outlet alone) => everythings fine!
When analyzing multiple connected domains (inlet + substrate + outlet) => PROBLEM!!
I can only see results (eg. stream lines) in one domain - not all three?!
Does anyone know a step by step tutorial/ example showing the solution of a similar problem?
Ex.: single phase gas entering through a free flow region through to a porous region with directional loss, and exit again through a free flow region?
Rgds
http://Libak.dk
flow in catalytic converter?
- 3Dcfd_libak_p94_filter.pdf
- CFD analysis of a Diesel Particulate Filter (DPF)
- (8.11 MiB) Downloaded 385 times
Brian Angel
Re: flow in catalytic converter?
It is possible to do a multiple flow domain in Code_Saturne including a porous media zone as we have done it numerous times recently. However, I'm not sure that there is a tutorial on this website that shows how to set up such a model. I'll speak with the other support engineers to find out what information there is and let you know.
Brian Angel.
Brian Angel.
Brian Angel
Please find attached an hdf and a xml file which shows how to set up a multi flow domain calculation in SALOME and Code_Saturne. Please go through the two files and the set up thoroughly and if you have any questions afterwards please let me know.
Brian Angel.
Brian Angel.
- DEMO_CodeSaturne.rar
- Code_Saturne xml file
- (2.11 KiB) Downloaded 302 times
- DEMO_Salome.rar
- SALOME hdf file
- (51.23 KiB) Downloaded 331 times
Thanks Brian!!
Your help is very much appreciated!
It seems my problem was with the stitching of the two meshes.
Thanks again
/Jesper
Thanks again
/Jesper
